Help please folks!!! MF 65 Multipower hydraulic problem
   / Help please folks!!! MF 65 Multipower hydraulic problem #1
Kentbrown
Uitenhage South Africa
Massey Ferguson 65
I am having difficulty with my MF 65 hydraulic pump I have put a bepco kit in and I am unable to turn it by hand is this normal?
   / Help please folks!!! MF 65 Multipower hydraulic problem #2
Hi .Kentbrown .
Check that you have fitted the pistons in the correct way ,they can be fitted the wrong way round and they will bind on the sides of the pump end plates.
When you strip the pump assemble the pistons ONE AT A TIME and run a straight edge across the valve chamber face ,the piston should have clearance there.
Also make sure the rear camblock ,the one with the reduced diameter that the control valve oscilator runs on is properly assembled that is the only two things that will make the pump hard to turn.
I am talking just the main hydraulic pump .
If you are talking the pump AND the auxiliary pump together no you wont be adle to turn by hand ,well it will be difficult ,if you put a pair of VICEgrips on the shaft it will turn .
Hope this helps . Regards
Hutch.
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
2024 New Holland T8.410 MFWD Tractor (A51039)
2024 New Holland...
2017-2023 Chevrolet Silverado Pickup Truck Bed (A49461)
2017-2023...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2013 DOOSAN G25P FORKLIFT (INOPERABLE) (A50854)
2013 DOOSAN G25P...
