help on satoh s650g early fluids question
   / help on satoh s650g early fluids question #1
okctractorman
satho s650g bison
Ok guys im new to this so hears the deal i thought my satoh was late i have done some research and discovered it was early model the clutch works fine the pto does not spin fast enough for nothing and i can stop it by hand the pedal on the right side when i pushed down it stuck down been putting penatrating oil on it 5 times a day it is getting free slowly but im confused what type of oil to use where to use the oil plug by the gear shifter i cant see any thing in it i see gears but no fluid the oil the 3 point lifts fine the oil plug behind seat shows full of fluid but when i first got the tractor i had to remove trans gear shifter and free up shafts it would not go into any gear and goes in gear and drives fine do i have a dry trans not letting pto ingage and what type of oil
goes in trans 80w/90? thanks bob
2007 Dutchmen Victory Lane 38SRV 40FT. Tri-Axle 5th Wheel Toy Hauler Travel Trailer (A48082)
2007 Dutchmen...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
UNUSED White Metal Roof Panels (A50860)
UNUSED White Metal...
2015 International DuraStar 4300 Crew Cab Mason Dump Truck (A48081)
2015 International...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
