Help on Remote hookups
   / Help on Remote hookups #1
Barnbeam
Southeast Ohio
Mahindra 2810 HST
Hey everyone, I've got a 2810 HST with a front end loader and would like to add rear hydraulics. I was going to get a kit from my dealer, but have been told it is on back order (it's been six months now). To be truthful I probably didn't want to pay the dealer price either, since they couldn't give me a price until they tracked one down. I have a log splitter for the 3ph and can't use it. My loader valve is a Nimco with seven lines hooked to it. It has the PB port that I believe feeds the 3ph. I know I need an open valve to run the rear off of. My question is what kind of valve? Something I can get at someplace like the surplus center website? Should the new valve have a PB port to run back to the 3ph or is the out on the new valve sufficient? I'm pretty handy and have worked on hydraulics before, just never had to replace or add a valve before so this part is new to me. Any input would be appreciated. Thanks for your time.
   / Help on Remote hookups #2
A 2 way single spool valve with PB port, and being you are running a splitter, a lock in detent would be a good idea. I hope this makes some sense and helps you. If not, let me know.
   / Help on Remote hookups #3
If you just want to power the logsplitter, you don't even need a valve since it already has one...You will extend the PB line to the rear of the machine, through a set of QD's then to the 3PH. When you want to use the splitter, just plug it into the PB "loop".
Lots of threads about this in the hydraulics forum also if you search...
   / Help on Remote hookups #4
That is correct, sometimes backhoe's are plumbed that way.
   / Help on Remote hookups #5
Here're the dealer-installed triple remotes on my 2008 Mahindra 5525.
The triple valve is made by Dinoil. This TBN thread has more info
http://www.tractorbynet.com/forums/hydraulics/107515-power-beyond-remote-hydraulics.html
The female QAs are Pioneer 4050-3P.
Use the TBN search on "Dinoil" for more info.
The valves were installed by my dealer Daves Tractor
Dave's Tractor, Inc - Home
Dave is a TBN member. Contact him for more details on those remotes.
John Deere 260E DOBBS Off-Road Dump Truck (A50322)
John Deere 260E...
2015 DODGE RAM...
2000 MACK (A50323)
2000 MACK (A50323)
4 Drink Hog Waterer (A50515)
4 Drink Hog...
2017 CATERPILLAR 930M RUBBER TIRE LOADER (A51242)
2017 CATERPILLAR...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
