Help on FEL reinstall
   / Help on FEL reinstall #1
Joeinindy
Jamestown, Indiana
Kubota L3410HST 2000
I took the FEL off my L3410 for the first time and I'm having one heck of a time getting it back on. I can get either the front pins in or the pins on the arms but can't get both to line up. If the front lines up and the pins go in, the arms won't drop down to line up, when the arms line up the front won't. HELP!!!!
   / Help on FEL reinstall #2
Hi Joe,
On my JD855 the installation process of the FEL involves getting it partially in position, then hooking up the hydraulic lines. Once hooked up, you then use the hydraulics to get the final position.
Dave
   / Help on FEL reinstall #3
Joe
Do you have the hydraulics hooked up when trying get the pins to line up. I do not take my FEL off very often.
My mind seems to go blank about all the little things that are needed to get the parts lined up.
   / Help on FEL reinstall #4
This may be a different beast alltogether, but I've done my FEL so often I can put it on or off in under a minute - maybe even less than 30 seconds except for the stopping the engine, hopping off part. Easy! Kubota BX1500.
Lines are hooked up, but the holes in the front or on the arms won't line up to allow the pins in, comes close but not enough.
   / Help on FEL reinstall #6
I never really did get the hang of taking mine off and putting it back on. Not according to the directions anyway. I just kept playing with the joystick until things lines up and it still took less than five minutes.
Are both the tractor and loader on fairly level ground?
Got the dude back on tonight, had to use a small sledge hammer to get the front holes lined up. Guess I just needed to convince it a bit. Thanks for the help guys.
   / Help on FEL reinstall #8
</font><font color="blue" class="small">( Got the dude back on tonight, had to use a small sledge hammer to get the front holes lined up. Guess I just needed to convince it a bit. Thanks for the help guys)</font>
Most likely you need to sand/grind back the paint buildup a little to allow a good fit. This is quite common on the new installs and only a little too much paint can really make it hard to get the loader back on. John
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
Non runner mower 72in (A51691)
Non runner mower...
2010 PETERBILT 367 HOT OIL UNIT (A53843)
2010 PETERBILT 367...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53473)
2022 New Holland...
