Help- NHTC21D vs Kabuto 7500/2410
   / Help- NHTC21D vs Kabuto 7500/2410 #1
Anonymous Poster
Epic Contributor
Hi,
The info has been great.
I'm narrowing down choices and need some advice.
My tractor needs are:
Finish mowing 3 acres with some irregularities
Annual brushhog of 3 acres pasture
Garden tilling
Possible pasture tilling for reseeding
Occasional loading/post hole digging
Mowing is my main job by far but I'd like to have ability to do more. I'd like to keep the tractor size down so I can mow most grass with this tractor and just finish a little around the house with a push mower. The NH TC25D seems too big with my trees and soft soil. The NHTC21D seems perfect but I haven't been able to see the Kabuto 7500 or 2410 (apparently both same body size) and they sound nice. Are they the same concept as the TC21 or are they bigger like the TC25? Pros/cons?
I'd appreciate opinions comparing these tractors. Also am I looking at the right size for my tasks? Thanks for any advice.
Purchased TC21D in May of 2000. It has 5 ft mid mount mower, frt loader. and R4 tires.Traded 1220 w/ 5ft mid mount mower.I looked at kubota 2400 but liked the TC21d better seemed better put together. Have around 80 hours on tractor. It seemed a little low on power at first, but seems to get better as hours are put on it.Great tractor I think you would like it alot.
   / Help- NHTC21D vs Kabuto 7500/2410 #3
I try and help w/ spec.
The B7500 and B2410 both have 3 cylinders.
B7500 holds 5.0 fuel and the B2410 holds 6.3.
Rear pto 540 rpm on B7500 & 2410.
Mid pto 2500 on B7500 & 2410.
3 point hitch on B7500 & 2410 category I.
B7500 weight [hst] 1367 lbs,B2410 weight [hst] 1477 lbs.
Ground clearance,B7500 12.0 & B2410 12.8.
I also have some spec on the front loader and backhoe if your intrested,and if you need somemore infor just let me know and I'm sure others here will be glad to help. /w3tcompact/icons/smile.gif
If you can locate your nears Kubota dealership,and try one out in there play pin. /w3tcompact/icons/wink.gif
I'm not much on NH, /w3tcompact/icons/frown.gif sorry I couldn't help.
Have fun and stay safe and /w3tcompact/icons/cool.gif
Thomas..NH
   / Help- NHTC21D vs Kabuto 7500/2410 #4
MN Guy,
I own a NH TC18 which is similar physically to the TC21. I sat on a B7500 at the county Fair and it was physically tighter than my TC18, felt more cramped. Don't know if this will matter to you or not, I am about 6'1" and 235 lbs.
I love my TC18 and would buy it again, got a great price, great dealer, and awesome tractor. I finish mow with a 5' Woods 3 pt. mower about 3 acres and just started rotary cutting about 4-5 acres of field with a Woods 4' rotary. Only regret is that I didn't get power steering which is an option on the TC18, I do have hydro and 4x4.
Good Luck, JimBinMI
We boys and our toys!
7ft Fork Extensions (A51691)
7ft Fork...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
48" JOB BOX (A51248)
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
JOHN DEERE 3032E TRACTOR (A51247)
JOHN DEERE 3032E...
