Help - Newbie - Massey 50ex
   / Help - Newbie - Massey 50ex #1
augmont
Total Newbie - Need help. My father in-law Massey 50ex ran out of fuel. He's outta cell phone range. I added fuel but still won't start. I'm sure there's a prime pump somewhere but i'm really not sure. I don't know anything about heavy equipment other than the occasional driving when he's here.
please help.
   / Help - Newbie - Massey 50ex #2
you'll have to bleed the system. Don't just crank it untill it starts, you'll end up out of fuel & need a starter. If you had a little air tank it would help to pressurize the fuel tank a bit. Follow the feed line from the tank, it should go to a lift pump on the engine, then to the filter. Sometimes there is a hand pump on the lift pump so you can prime most of it by hand. I don't think there is on yours. So, crack the bleed screw on top of the filter, if you can't find it loosen the outlet line going to the injection pump, and try to get fuel out of there. When you do, tighten it & go to the injection pump. there should be a lower bleed screw & an upper. 5/16" wrench size, bleed the lower one first, then the upper. The upper will have to be bled be cranking the tractor. When fuel comes out there, crack the injector lines & crank till a steady squirt comes out, tighten & you should be all set.
Don't crank the starter for more than 25-30 seconds at a time & let it cool for a while between cranks. Make sure your battery has plenty of power.
Then scold the Father-in-law for running out of fuel, this is a totally unacceptable event that should never happen to anyone on any piece of equipment.
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2013 BIG TEX PRESSURE WASHER TRAILER (A52472)
2013 BIG TEX...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
1997 Freightliner FL60 Truck, VIN # 1FV3GJBC6VH725847 (A51572)
1997 Freightliner...
2018 FORD F-150 (A52472)
2018 FORD F-150...
