Help needed - Tandem roller setup
   / Help needed - Tandem roller setup #1
HappyCPE
Hunterdon County, NJ
JD 4320
I have acres of lawn and pasture to reseed and roll. I bought two (2) 48" wide lawn rollers from TSC and would like to pull both at the same time, side by side, to get a 8-9' wide pass. [The tires on my tractor are set to be about 96" wide]. Each roller has a yoke on it, with a cat 0 pin, so it can be pulled by a lawn tractor individually; I've got a flat bar with holes in it, to join the two. That's at the front.
Now, my problem is at the back. Going around turns the two rollers do not track together; combined with some hills and hummocks, the two yokes bang into each other and sometimes ride up on top of each other. I need something that will spread the two rollers apart and keep them from touching, but will still allow differential movement side-by-side and up-and-down.
I'm imagining something like a rubber stick, or a torsion bar, that will flex but still keep the two yokes apart. Unfortunately I have no idea where to find such a thing, or how to attach it. Help!
I'm also hoping for an easy solution, something that doesn't require welding. I can get that done for me if I need to, along with getting some parts made.
I ask for help from you folks who are more creative than I, and who have graduated from the school of hard knocks!
Rollers: Ohio Steel Industries, lawn and garden equipment tractor drawn implements steel fabrication plastic extrusion lawn rollers lawn carts spreaders sprayers welding MIG TIG manufacturing folding ramps aerators structural steel bridge construction rigid PVC HDPE polypropylene twin screw extruder
Click on Lawn & Garden, and scroll down to the model 48T. No picture, but it looks like the 4T without the handle.
   / Help needed - Tandem roller setup #2
Maybe something like this? Either weld a pin or drill a hole in the support bar and run a bolt through the hole with some nuts to hold the bolts.
Enco - Guaranteed Lowest Prices on Machinery, Measuring Tools, Cutting Tools and Shop Supplies
   / Help needed - Tandem roller setup #3
Here is my interpretation of what you have, with what I think you need. Hope it helps, but you will either have to have framework welded up or pieces drilled and bolted together.
  • Tandem roller with single pivot point.pdf
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
New/Unused 2025 CFG QK16R Mini Excavator (A51573)
New/Unused 2025...
434669 (A48836)
434669 (A48836)
