Help Needed - RC rover using hydraulic Drive
   / Help Needed - RC rover using hydraulic Drive #1
Simon3
SA, Australia
CASE 1835B
G'day there
First post so bare with me ;)
I'm needing some help building a remotely controlled 6 wheel drive rover using a hydraulic skid-steer system, I'm posting in here because it痴 the only place I could find on the net with a decent hydraulics forum ;)
The plan is to have 2 hydraulic motors, one each side like a bobcat driving 6 sack truck wheels by chains.
This will be controlled by a simple implement type valves actuated by RC servos and it will be powered by a 6.5HP petrol motor.
Heres the parts I need help with
I wanted to use some old motors of a hydraulic reel mower BUT are these capable of reverse?
Also what size pump will I need to drive these motors? I was looking at using one of those dual stage pumps like they use on those cheap log splitters because I know they are usually coupled to 5-8HP motors
The whole machine should weigh between 40-50KG
Thanking you
Simon
   / Help Needed - RC rover using hydraulic Drive #2
G'day there
I'm needing some help building a remotely controlled 6 wheel drive rover using a hydraulic skid-steer system, I'm posting in here because itç—´ the only place I could find on the net with a decent hydraulics forum ;)
Thanking you
Simon
Simon.
Is that 110 lbs total weight you want to control/power? Is this for some kind of work, or is it for exhibition?
I think your estimated weight way to low. Have you considered all the parts weight, engine, hyd motors x 2, chain,hyd valve, hoses, etc.
Baileys.com has the remote control for hydraulics, and they also have pumps and motors at decent prices. I have never messed with hyd reel motors, but most hyd motors will reverse.
Have you seen this video?
http://www.youtube.com/watch?v=BD0zh0ruiBE
YouTube - RC Skid Steer eBay # 170281058241
http://www.youtube.com/watch?v=fI_rcegpMzQ&feature=related
http://www.youtube.com/watch?v=oY40MvqpFiM&feature=related
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
