3-Point Hitch Help needed in reassembling 175 hydraulic lift cover assembly
   / Help needed in reassembling 175 hydraulic lift cover assembly #1
EdinOR
Oregon
69 Massey 175, 51 JD B, 48 JD H, 48ish York Turn O Bout
Hello,
My lift didn't work so I tore into it to repair it. Found problem and with a few new parts I'm ready to reassemble it. I took lots of pics.... but apparently not enough. I looked to no avail on forums and YouTube but cannot find out what I need to know. It was assembled wrong when I got into it, so when I took it apart some of it just all fell apart....hence my problem. ANYWAY, what I need to know, and pics would be best here, if possible, is exactly where the two cams position into/onto the Draft Control link assembly and the Position Control link assembly.
Thank you.:confused2:
Thank you Agvg. You are correct, it is much the same with a few differences. I was able to get things figured out though with the help in the 135 manual that you provided a link to. I also had a few other questions that it was able to answer that my 175 service manual didn't cover, even though those parts were the same on both models. Thanks again.
2020 FREIGHTLINER 26' BOX TRUCK (A51247)
2020 FREIGHTLINER...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
