crystallattice
Hi Guys,
I'm planning on building a rotary air percussion drill rig for well drilling. I need some help with the hydraulic system design.
The system will have the following:
-High torque rotary head (hydraulic motor with planetary gearbox - ready made by Augertorque) 80-240Bar, 40-85LPM, 42-90RPM
-Hydraulic motor geared down 1:2 with sprocket and chain to drive head up and down mast using chain. 160 RPM, 380NM, 60LPM
-Hydraulic motor for driving wire rope winch, used to lift new section of drill pipe, this will only be used when the head is raised and stationary. 46NM 20LPM
Operation needs to be as follows:
Rotary head needs to be set in motion and stay running with speed control (flow restriction) and possibly also torque control (pressure reduction) These controls must preferably be set and not require a lever to be held in a certain position. The head must also be able to rotate in opposite direction with the speed/torque controls also functional (maybe the torque can be max and the speed controlled with the lever to make the control system easier/cheaper).
Whilst the head is rotating, the head must be lowered by forcing it down, again speed and or torque controlled. At some stage when the drill string weighs more than the downward force required, the head must be pushed up to counter the weight of the drill string but still proceed downwards (a certain size drill bit requires a specific downward thrust to be maintained) Some form of visual feedback would be very useful as to indicate what is happening with the drilling operation.
All the motors are gear motors, the head motor would probably get a motor spool so it can freewheel (will be necessary when using spanners to remove drill string from head ) but the other two(head up/down and winch) will get a normal spool so as to hold their position, will it work or will it require a hydraulic brake?
I have a Kohler 25hp command engine which I'm planning on using for the hydraulic power pack, using a 60 or 80LPM single stage hydraulic gear pump, 200Bar@3500rpm.
I was planning on getting a three lever monoblock valve as they are cheaper than individual valves but not sure if it will give me the freedom to do what I want to do.
I did a back of envelope calc on the max lifting power of the head lifting motor and it worked out to something like 6000Kgs with a 1:1 ratio and a 160NM motor using 120mm sprockets, is this plausible? Sounds like a lot for such a small thing!!
The rotary head will be used at max 30RPM So can I assume that I will also use only a third of the flow(85LPM = 90RPM so 30RPM = 85LPM/3 = 28LPM) Also the head will move down quite slow, so the up/down motor (which will require 60LPM to do about 0.5m/sec, will now require a lot less) So I'm guessing the 60LPM pump will be enough, too a big pump = hot oil.
Your comments, suggestions, warnings and criticisms are welcome...
