Help! Need to find ring & pinion.
   / Help! Need to find ring & pinion. #1
winchman
Bronze Member
western, pa
kubota 2410 with loaded R4s
I'm trying to help my brother out. He has a 1990 dodge diesel 3/4 ton 4-wheeldrive. It has an original Dana rear-end, 307 gear ratio, 10 bolt cover, BM#605-311-1. From what he has been told, Dodge only used this rear-end for two years to try to improve mileage. He and I have called all salvage/junk yards in our areas. He just needs the ring & pinion, but is willing to buy the complete axle housing if he has to. Only other option is to get another rear-end with a different gear ratio and eliminate the 4-wheeldrive. Any suggestions or, leads would really be appreciated.
Thanks,
winchman
   / Help! Need to find ring & pinion. #2
You might try http://www.4wheelparts.com/. They have a large selection of gears, especially for Dana axles, and seem to have prices as good as anyone. You probably don't want to install used gears in an axle. Once the ring and pinion are broken in together it is next to impossible to install them in another axle and get them to mesh properly. Improper installation will make the gears noisy and will drastically reduce their lifespan. Hope this helps.
I love the smell of diesel in the morning./w3tcompact/icons/smile.gif
   / Help! Need to find ring & pinion. #3
Drive Train Specialists in Warren, Mi 1-800-521-0628
Thanks Guys! Found the ring & pinion at DTS.
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2015 Volvo VNL 64T (A53473)
2015 Volvo VNL 64T...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Pallet of Crafco Asphalt Sealant  (A52384)
Pallet of Crafco...
