HELP! Need rear remotes for auger downpressure on Kubota L2350DT
   / HELP! Need rear remotes for auger downpressure on Kubota L2350DT #1
5starfenceco
97 Kubota L2350DT
So I have resorted to researching this for myself after numerous dealers couldn't help us. We purchased an L2350 (1997) and a Danuser F7 auger with down pressure attachment a couple weeks ago with the thought that we could have a set of rear hydraulics installed. Well, turns out getting rear hydraulics on this model tractor is a lot harder than we thought, and without down pressure on the auger we don't stand a chance in the rocky Missouri soil. Anyone have any suggestions, or perhaps a parts list we can piece together to get this figured out??
   / HELP! Need rear remotes for auger downpressure on Kubota L2350DT #2
Welcome to TBN:D
Do you have a loader now? If so then you can use the PB (power beyond-sometimes labeled BYD) port on the valve to feed another valve mounted to the rear. The cheapest way would be to just run long hoses from the dump/curl circuit (after disconnecting the lines that feed the loader) and use you joystick to operate the downpressure cylinder.
If you search terms like these here in the Hydraulics forum you can read LOTS of threads:
remote
power beyond
L2350
I do have the front loader. Would I be able to use the bucket and down pressure at the same time or is that a switch for one or the other?
   / HELP! Need rear remotes for auger downpressure on Kubota L2350DT #4
you could unplug the bucket curl lines and plug in the hydraulic post hole digger. the bucket up and down would still work.
if your existing bucket control valves have an additional port available for power beyond (it should be labeled and have a cap in place) you can add an additional valve for rear remotes.
I got it figured out. We had a switch installed that when flipped one way the up/down motion on the boom works along with the bucket movements, and flipped the other way the down pressure cylinder works along with the bucket movements. So its either the boom works or the cylinder works, and its awesome really. Real simple. The guys at S&H Farm Supply here in Rogersville, MO did a great job :thumbsup:
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
Kubota L5030D 50HP Front Loader Utility Tractor (A50322)
Kubota L5030D 50HP...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
