HELP!! NEED LOADER CYLINDER FOR 4940C
   / HELP!! NEED LOADER CYLINDER FOR 4940C #1
BILL_K
Bronze Member
Golden Valley,Arizona
YANMAR 186D,MONTANA 4940C
i NEED THE BUCKET CURL CYLINDER FOR A MODEL ALN47C ANSUNG LOADER. MONTANA WILL NOT HELP ME, SO I NEED TO FIND A DEALER WITH OLD STOCK .
THE MONTANA PART NUMBER IS ALN4705100.
THANK Y0U FOR ANY HELP
BILLK
   / HELP!! NEED LOADER CYLINDER FOR 4940C #2
What is wrong with the cylinder you have ( assuming you have the old curl cylinder). Almost any cylinder can be rebuilt if it is just seals, a new rod, etc. Chances are, surplus center, Baileys,etc might have a similar cylinder as well. Might even be able to switch both cylinders out with cylinders that are same or just slightly different...not enough to make a difference, for less than the cost of a single OEM cylinder.
THANK YOU.
I WAS ABLE TO GET A NEW ROD MADE AND AM BACK AT WORK
BILLK
2025 Mower King SSECAG-Y Hydraulic Auger Skid Steer Attachment (A50325)
2025 Mower King...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
Misc. Motorola Chargers and Battery Maintenance System (A50325)
Misc. Motorola...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
