HELP MY BABY
   / HELP MY BABY #1
scottgardner
I was cutting grass today on my 2002 tc33d and it died.I got off to get a drink of water and left it running got back on an started off the it just died.I had been cutting for about 2 hours had been doing fine then it just died.The engien will turn over and sounds like it should start but it dose not.WHAT IS WRONG???????/
   / HELP MY BABY #4
If the engine will turn over it eliminates many of the safety interlock switches such as the seat, PTO, and brake switches.
With the engine turning over without firing indicates a fuel delivery problem. You can't trust fuel gauges - do you have enough fuel? Fuel Filter filled with water/debris? Fuel suction in tank plugged with debris? Did a branch swing up and hit your fuel shutoff? Wires disconnected from the fuel solenoid (located next to the injectors)?
I have a Class III TC40D, so I can't be really specific on locations of these, but the theory is the same.
   / HELP MY BABY #5
Sure sounds like you ran out of fuel. Refill the tank and bleed the line and the injectors and it should start up. As has already been written, the fuel gauges can not always be trusted, yours might be stuck.
There are instructions in your operators manual to bleed the line and the injectors. It is a simple process (I can do it without getting dirty) and pobably only requires only a Cresent wrench.
Assuming you ran it out of fuel: Find your fuel filter on the side of your engine, just after the fuel filter will be a nut that can be loosened to bleed out air. Loosen the then and crank over the engnine until you see a bit of diesel bubble out of the nut. Retighten the nut. Then trace the fuel line a bit farther an you will see it split off into 3 small lines each of those lines goes to one of 3 cylinders on your engines. At the point were the line goes into the cylinder there is a compression nut, loosen the nut farthest away from the fuel filter and crank over the engine until you see a bit of fuel bubble out. Retighten the nut. Then do the middle cylinder's injector the same way. Now you have bled the air out of 2 of the 3 injectors, you tractor should start. It will run rough until the air works its way out of the first line. If you want you can bleed all 3 lines. I've gotten them to start up after only bleeding 1 line, but they sputter quite a bit for 3 or 4 minutes while they are running the air out.
   / HELP MY BABY #6
Had a similar problem on my Deere. It was a fuse in the fusebox.
   / HELP MY BABY
Got it fixed guys did not run out of gas.Had half a tank.just bleed the lines and she started right up.When i bought gas that day it was coming out very slow even a truck driver was saying so.Must got a bunch of trash.I do not like to buy there but it was so much closer so i did. never again IT was on the new one night about someone buy gas there and got a tank full of water.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
19102 (A51694)
19102 (A51694)
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
