Oil & Fuel Help! MF 1100 won't start
   / Help! MF 1100 won't start #1
Lauraezersky
Bobcat
I have a Massey ferguson 1100 I drove it to shop shut it off changed fuel filters and now I can't get fuel to pump through. I blew the lines out cleaned the pump still nothing... What do I do?
   / Help! MF 1100 won't start #2
Sounds like you have a air lock and will have to bleed the fuel lines.
I bled the lines, are so I think I did , I don't have a manual and wasn't sure where the bleed screws are. There's no fluid coming through the top side of the mechanical pump ( top side). It's going in but not coming out.
   / Help! MF 1100 won't start #4
You may need to bump the engine about 1 turn. Cam may have stopped with pump lobe holding hand lever out of stroke, will cause the hand primer to keep from moving the diaphragm.
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2015 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2015 FREIGHTLINER...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
