help me understand 80w90 vs 75w90
   / help me understand 80w90 vs 75w90 #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
The manual for my JD 2320 calls for 80w90 in the front axle. It lists no other recommended weights.
The rotary cutter manual gives you a chart showing the temperature range of a whole bunch of different weight gear oils. Obviously the a 75w90 gives you a greater range than the 80w90.
I was going to buy some amsoil 75w90 for my pick up differentials - Is there any reason I cant use the 75w90 instead of the 80w90 in the tractor to keep it simpler?
thanks
Brian
   / help me understand 80w90 vs 75w90 #2
thanks
Brian
use 75w-90 and be very happy. I have used their series 2000 stuff in my bx22 and performed great. It is really fill and forget!
   / help me understand 80w90 vs 75w90 #3
Use the 75w-90.
It's like using 0w30 engine oil instead of 5w-30. The 0w-30 is better.
Ralph
   / help me understand 80w90 vs 75w90 #4
The first number(75) represents the viscosity of the oil at cold temperatures and the second(90) represents the viscosity at warm temeperatures. The first number is calculated differently than the second number and that's why the first number isn't higher. The second number is what the viscosity will be when the tractor is warmed up(most of the time it's being used), therefore it's crucial that the last number is 90. The first number being lower(75) rather than 80 is better yet because it will flow and lubricate before the tractor is warmed up. It can be confusing and even sounds backwards but that's the way it is. The chemists that decided on these measuring systems just thaught it would be funny to confuse the rest of us:D.
   / help me understand 80w90 vs 75w90 #5
And, to give us a reason to have forums like this and BITOG!! :D
   / help me understand 80w90 vs 75w90 #6
fyi
snippet from a GM Technical Bulletins
This bulletin is being issued to inform dealers about the compatibility and usage of the new Fuel Efficient SAE 75W-90 Synthetic Axle Lubricant,.....................
It is recommended that synthetic lubricant be used when changing rear axle lubricant for the following reasons:
Potential fuel economy
Lower operating temperature under severe usage conditions ........
As a product improvement, this new lubricant has been released into 1999 current production C/K vehicles built after the above VIN breakpoints
   / help me understand 80w90 vs 75w90 #7
Most all 80W/90 gear oils are conventional, 75W/90 is usually synthetic. That's the main difference and as far as using one in place of the other it's not a problem as long as it's the correct spec.
7x16 Landscape Bed (A44391)
7x16 Landscape Bed...
2002 Ford Ranger Ext. Cab Pickup Truck (A44572)
2002 Ford Ranger...
PETERBILT FRONT CLIP (INOPERABLE) (A45046)
PETERBILT FRONT...
2013 Cadillac SRX Luxury SUV (A42744)
2013 Cadillac SRX...
2025 Forklift Safety Basket (A42742)
2025 Forklift...
2018 Ford Transit 350 (A44501)
2018 Ford Transit...
