Help me to refine my decision...
   / Help me to refine my decision... #1
mygoatboy
Central MA
Ford 3000
Hello,
I have been looking at tractors for starting up my farm. I will need to prepare 5-10 acres of apple orchard for turning into a truffle farm and then I will plant about 500 trees an acre on it. I was planning on tilling the whole thing so that harvesting the underground truffles would be easier. I would like to be able to use a 100" or so tiller because I plan on trying to add 5 acres a year of truffle farm. What size tractor would you recomend? I would really like a 4wd diesel because it will be used for snow removal. Also it will be used for small square baling too.
   / Help me to refine my decision... #2
I think you first need to go find the tiller you want and then see what size tractor is recomended to power it. Here is a site with a 90" tiller and they say 40 to 70 HP tractor Rhino Tiller
Something in that HP range should do what you want, but I would lean more toward the higher end, just so you would not be working the tractor at its maximun limit all the time.
   / Help me to refine my decision... #3
The Rhino tiller is MFG by Sicma. You might want to look at the CCM Gear Drive Tillers.
Thank you to those that replied. Will the tiller remove roots or will I have to do that with a seperate attachment?
   / Help me to refine my decision... #5
No, the tiller won't remove the roots. Ok, I lie, it will but you will have to keep pulling them out of the teeth and they can tear a good tiller up right quick. /forums/images/graemlins/grin.gif
   / Help me to refine my decision... #6
Here is one way to remove apple tree roots:
Link
Mighty fine hay tractor also!
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example.
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
VULCAN STAINLESS STEEL STEAMER (A51248)
VULCAN STAINLESS...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
LMC LOT IDENTIFIER 9 (A53084)
LMC LOT IDENTIFIER...
