Help me put together an inline hydraulic pressure gauge
   / Help me put together an inline hydraulic pressure gauge #1
BigMike50
Uranus
2012 JD 3520 Cab 1996 JD LX172 1985 Wheel Horse
I have a john deere 3520 and I want to install a guage inline with one of the ports on the loader and the quick connect ports on the tractor. I already have the guage. I would need an inline T with a male quick connect on both sides. Is there anywhere that sells the setup? What else would I need. I already have a 3000 psi gauge connected to an 18 inch section of hose with a male quick connect on the end. I would like to plug this right into an inline t as mentioned
   / Help me put together an inline hydraulic pressure gauge #2
The best place for a hyd gage is in a tee in the IN port of the FEL valve.
It will reflect anything the hyd is doing.
Set it up where you can see it to monitor and trouble shoot the hyd system.
can you tell me where and what T to get for this
   / Help me put together an inline hydraulic pressure gauge #4
Any place that sells hydraulic fittings will have tees
Just dont go get one from the plumbing section of your nearest box store.
   / Help me put together an inline hydraulic pressure gauge #5
You need a hyd tee that will connect to your In port, and your removed hose will connect to the other end, and an adapter for the gage to fit in the tee.
If your valve is too low for good visibility, add some hose to the gage port.
If you do not need a semi-permanent hyd gage connection, then do this.
Install a tee in the same spot as above, with a male 1/4 in QD.
Here are some pictures of test sets made up by TBN members.
They should cost about $30.
Just plug in the gage to test.
yeah I have one 3 miles down the road. The prices are rediculoius in there compared to the internets. I paid 70 bucks for a guage, hose and a quick disconnect.:thumbdown:
Here is a liquid hyd gage for about $12 plus shipping.
3000 PSI 2.5" LF LM GAUGE
you see that's about the same one that I paid 40 for at the local hydraulic shop. I got ripped off. I have a grainger nearby too so ill stop in there tomorrow. ill bet there stuff is cheaper.
   / Help me put together an inline hydraulic pressure gauge #9
Dont be too sure. Grainger is ALWAYS high to to private individual. Now companies and whatnot get 40-60% off them prices.:mur:
   / Help me put together an inline hydraulic pressure gauge #10
If the QD on your gage matches the other QD's n your tractor, you can just plug into any valve work ports QD and check for pressure and how much.
For permanent viewing, install it in a tee in the IN port of the loader valve.
So any spool you operate, the pressure will show on the gage.
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2014 FREIGHTLINER CASCADIA MID ROOF SLEEPER (A54607)
2014 FREIGHTLINER...
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2015 New Holland Boomer 47 4WD 45HP Utility Tractor (A55787)
2015 New Holland...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2014 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2014 Ford F-350...
