Help me pick
   / Help me pick #1
diesel_nut
Tennessee
~'88 1872(sold); '08 GT2554
I know you've been thru thisa million times but....
Relatively small yard, about 1 acre. All Bermuda grass. Grows like crazy when it's 90+ out! I currently have an older Cub 1872 with a 60" deck. The tractor itself cuts at a high speed(goes fast). It is becoming a typical old tractor( a pain to fix every time it gets used).
I have been looking at new Cubs particularly the 1554 and 1054(?). Anyway the major difference is the Command vs. Courage engine and some optional equipment down the line. I have also checked out ZTRs and they are in the mix as well.
I want to keep to a 54 deck or larger or maybe a 50 in a ZTR.
I'm afraid with the ZTR I will give up the use of the tractor for other uses(towing trailers, moving a bass boat across the yard, yard work, etc).
Help /forums/images/graemlins/smile.gif
   / Help me pick #2
Your needs aren't too demanding so I would think a 1000/1500 series would do the job well. I also like the "tractor" style mowers for pulling, using attachments, etc. Did you have a certain price range in mind?
   / Help me pick
I was wanting to keep things near $3,000.
I have another concern. I drove the 1554 and it seems to go soooooooooooo slow. Atleast this is compared with my older 1872.
I just put a new carb on the 1872 and it seems to be running great now(the reason for considering a new tractor).
Now I have this dilema. Do I keep the 1872 and just run it into the ground and accept $100 here and $300 there or do I sell it for what I can get for it(which it should still bring near $1,000 I'd guess) and get a new one.
I am very leery of new ones because of the slow top speed.
The new ones do turn much sharper however.
   / Help me pick #4
Since you're a "diesel nut" there is only one choice, actually 2 this year...just step up and get a Cub 5234 diesel or the new 5264 diesel. Sure, they're way out of your price range and overkill for 1 acre, but so what. You'll love the 4 wheel drive, hst, 3 pt hitch and a Diesel Engine! You can do it! /forums/images/graemlins/grin.gif
   / Help me pick
I have looked at some diesels and yes it is a bit much for my needs at present but oooooooooooooh the smell of diesel in the morning /forums/images/graemlins/smile.gif
__________________________
Powerstroke Excursion
2 VW TDIs
2024 Bintelli ActivEV Pulse Electric Cart (A51694)
2024 Bintelli...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A53843)
BAUER ATD-750...
2012 Chevrolet Equinox 1LT SUV (A51694)
2012 Chevrolet...
