Help me install Curtis Cab with Rear Remotes!
   / Help me install Curtis Cab with Rear Remotes! #1
Trucker1
Western Maine
John Deere 4510
Hi all,
I just picked up a Curtis soft side for my JD. I have the rear remotes and power beyond. I was wondering how any of you with cabs got around the remotes and hydraulic lines. I'm just looking for ideas/pics of how yours is set up.
I'm thinking of cutting out the section of the rear mount/plate and retrofitting it with a "1/2" box that will go around the hydraulic lines, inside, behind seat. That would essentially leave the lines outside the cab. Then I can bolt the steel box on with weather stripping from inside, behind seat.
Any thoughts would be appreciated.
   / Help me install Curtis Cab with Rear Remotes! #2
Dear Trucker1
I just removed my soft side, leaving the roof and windshield on. I carefully cut the soft side not the clear part for the hydraulic lever to pass through, leaving the hoses outside.
I tie the eylets down with work boot laces.
One winter I passed too close to a cut off branch and pierced the vinyl side window ( duct tape ) repair for now
I think you are on the right track.
Craig Clayton
Truck Bed (A50774)
Truck Bed (A50774)
2010 Toyota Corolla LE Sedan (A50324)
2010 Toyota...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
