Buying Advice Help me find the right tool for my property (tractor, backhoe, mini ex, skid)??
   / Help me find the right tool for my property (tractor, backhoe, mini ex, skid)?? #1
JohnFourteenSix
Bronze Member
Kissimmee, FL
JD 3032e, Bobcat T180, Mustang 3003
I bought a used John Deere 3032e from a dealership a few months ago for $15000. It has low (<200) hours, and it's a very maneuverable machine. But I'm coming to realize I'm not using it for any of the tractor related tasks that people use tractors for. I have no grass to mow, no bales of hay, no plowing, tilling, etc. I graded my driveway once.
The main tasks I'm finding myself doing is trying to dig deep drainage trenches/swales, using a posthole digger for planting seedlings, and just digging in the ground for dirt and moving it around the property. I also have a few utility trenches (3 ft deep) that I need to dig. The tractor fails at all the tasks except for using the posthole digger.
Based on some research, it seems a mini excavator is the best tool for the job, but the pricing seems cost prohibitive, and I'd be losing the maneuverability and speed of the tractor (if I sell the 3032e to fund the excavator). I can't afford to spend another $15-20k+ on an excavator (I'm looking at 3 ton units). I've been looking at the JD 370B backhoe (made for my tractor), but that looks like another $8k, and I'm not sure if the tractor's hydraulics can really make it do a whole lot anyway. Furthermore, it seems like backhoe attachments don't retain their value as much as the actual tractor itself.
The option that seems most viable is to get an older large tractor with a backhoe attached to it. This should land me at around the same $8k cost (and keep the 3032e), but with a much larger and more capable machine that even if not ideal for digging, will certainly not be underpowered. The problem with those is that they are mainly 2wd so I would need to propel myself with a bucket once I get in the muck.
I've looked at all the threads that say to rent an excavator, but renting is only good when you have everything planned out and have a specific task at hand. For us, it's likely going to be a lot of trial and error until we figure out what works.
My overall budget is around 20-25k, and I need either one or two machines that can:
  • Use posthole digger in tight areas
  • Carry dirt around
  • Carry stuff on forks (boxes, lumber, etc.)
  • Dig 3-4 ft deep trenches in muck
  • Excavate small retaining ponds in muck
  • Perform some kind of grading
I'm in what's known as Florida flatwoods, so I have muck, sand, and a water table that's about 4 ft below the surface, so little point in digging below that.
   / Help me find the right tool for my property (tractor, backhoe, mini ex, skid)?? #2
One thing some people have suggested when a poster mentions some heavy digging to be done within a few months is to buy an older machine, do the work, then sell it. Many claim you'll get all or most of your money back out of it. But that pre-supposes that you have the money to spend initially.
I've dug holes, removed stumps and loosened dirt with my BH, but haven't taken on any long trenches yet.
If you're looking to replace the JD with a do all machine, my 125 was well within your budget at a little under $19K. The same sized JD was closer to $22K.
   / Help me find the right tool for my property (tractor, backhoe, mini ex, skid)?? #3
SNIP...
SNIP...
I've had a lot of experience with hoes, and never thought I'd recommend a 3pt backhoe - but for what you want it is the perfect tool.
You've go the right type of soil and the right type of projects and the right tractor to use it on.
Getting the right 3pt hoe enables you to keep your tractor - Your JD is way too nice of a machine to just get rid of without giving it a chance.
I used to have a 3pt. mounted backhoe, on a 33 hp tractor and it did everything you want to do just fine. In fact, I've had several. The hoe doesn't have to be a JD; several companies make good ones. Yes, good 3pt hoes are expensive, but they maintain their value exceptionally well. If you use it a couple of years you may well find that you can get most or even all of your investment in the hoe back. Good quality used ones get snapped up quick.
You do want to find one that is heavily built and attaches to the tractor well. The very best ones have some sort of sub-frame to take the stress of the hoe. Yes, that means get a good one; not a cheap one. The good news is that your budget is reasonable. I get you can get a good 3pt hoe that fits that budget.
This all works especially well because you only need to dig to a relatively shallow depth. Hoes go way up in price when you start to want them to dig deeper. For what you want there are some nice 3pt hoes - Bradco is one - built real well but the trade-off is that they don't dig very deep.
The tractor hydrauics don't enter into the picture. Most 3pt backhoes - and especially the type you want - will have their own internal hydraulic pump and fluid reservoir which is driven from the tractor PTO.
A older used commercial TLB (tractor/loader/backhoe) is a reasonable option if you like to do mechanical projects. But know that by the time they get down to your budget they are going to require quite a bit of wrench work to get them up to a reasonable working condition - though if you enjoy wrench work it's an OK way to go.. And when you get it done you can sell off the 3pt backhoe that you used on your JD to get dirt work done while you played mechanic to the old TLB...
I know, because I've gone that route myself, some years ago I sold our 3pt backhoe and bought an older TLB with 6000 hrs on it. It's OK; not what I'd recommend for everyone. Not everyone enjoys doing mechanical work. For me, it's a hobby.
I hear you on not wanting to rent. I'm the same way. I like to work on a project when I want to, and not be constrained by having to go rent something.
Good luck,
rScotty
   / Help me find the right tool for my property (tractor, backhoe, mini ex, skid)?? #4
I'd think hard about using a 3pt backhoe with no subframe. Supposedly they can be hard on the tractor, with some unfortunate people breaking their transmission cases. With how much my BH attachment moves my heavy Branson around, I can see how that might happen. And I think your Deere has an aluminium case.
Try checking around at Deere dealers for a used BH attachment with the subframe for your tractor. Sometimes people buy them with the tractor and don't use them much, or they trade in a tractor with a BH and the dealer splits them.
Your Deere has a 5.something gpm hydraulics. That's not as much as some other tractors, but it's the pressure that does the work. The flow determines how fast. Many people run their tractor at lower rpms to slow the BH down some. I've been running my Branson at 2000 rpm (PTO rpm is 2500) when using the BH. It's plenty fast for me as a novice BH operator.
   / Help me find the right tool for my property (tractor, backhoe, mini ex, skid)?? #5
I'd suggest one of the sub $3K towable trenchers first.
If you mean one of those harbor freight trenches, I've seen videos of them in operation. I don't see that working in my case; also the tires are way too small.
I should have also mentioned that while I do have sandy soil, I also have quite a bit of roots
   / Help me find the right tool for my property (tractor, backhoe, mini ex, skid)?? #7
I agree with Eric on the flow rate 5GPM is sufficient to run the BH as you don't run the loader/BH at the same time and most of the time I run at 1500 RPM for most digging for smoother operation.
The 370 Deere BH is made for your machine and attaches to the frame of the tractor vs the 3PT arms and since it is built for your machine is the better choice as the dealer will stand behind it from a warranty perspective. Yes you can get a $6K or less unit, but the savings over time are nominal.
Also get a mechanical thumb - aftermarket are fine - they are invaluable for roots/stumps/palmetto you have there in FL.
On the used machines in your price range, unless you are very fortunate to find a low hour machine for $8-15K it will need care and attention as Rscotty states, so my vote is buy the 370.
So I tried digging around a bit more with the bucket, to remove my residual piles of dirt. My soil is technically "sand", but that's only after you get past the thick layer of muck that's sitting on top of it -- about a foot or so thick, and it gets everywhere and the most problematic areas (i.e. the ones I want to dig in) are perpetually soggy. It struggled to lift a bucket of that stuff. My gut tells me the 3032e machine is too weak. Is there another kind of test I can do?
   / Help me find the right tool for my property (tractor, backhoe, mini ex, skid)?? #9
  • Carry dirt around
How deep and how wide?
   / Help me find the right tool for my property (tractor, backhoe, mini ex, skid)?? #10
You will want to look at tractors with frame mounted removable backhoes.
UNUSED FUTURE SKID STEER SIDE SHIFT FORKS (A51244)
UNUSED FUTURE SKID...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
UNUSED 2025 INDUSTRIAS AMERICA 7014 DUMP TRL (A51243)
UNUSED 2025...
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
