Help Me Find A Pulley
   / Help Me Find A Pulley
Could you keep the stock clutch and sprocket, and convert the cutting head to chain sprocket? You could then fit a chain with the cutting teeth ground off, or perhaps just buy a toothless drive chain.
The Forest Service had some experimental units which were supposed to get you down to bare mineral soil, by flinging the covering organic soils all over the poor fool running it. They had a chain sprocket on the flinging head.
Thats not a bad idea. But I might just buy one of the cheaper ones that take a chain and be done with it. They are half the cost anyways. Just need to buy a toothless chain. I liked the compactness of the system I bought, seems like there is going to be a lot of leverage having this thing on the end of a 20" bar. Not sure if that is a good or a bad thing yet.
   / Help Me Find A Pulley #42
The new pulleys have the clutch drum attached. Which is why the kit is brand and model specific. They probably will not work with the Makita clutch. So, you have to either attach a belt pulley to the Makita clutch drum or convert the cutting head to work with the Makita chain.
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
2021 Deere 333G (A53317)
2021 Deere 333G...
Rockport Mobile Command Center (A59230)
Rockport Mobile...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
