Help - loader won't go up JD5410
   / Help - loader won't go up JD5410 #1
ejb
Platinum Member
Hey all. Need some troubleshooting assistance. My JD5410 with a 541 loader stopped working today. Used it two days ago and worked perfectly, today the hydraulic system seems to be running fine - bucket will curl up and down, and if I use the rear hydraulics they seem to have power, but my loader will only go up or down about 4 inches.
Plenty of fluids, seems to have plenty of power - what else can I check? If it didn't move at all I would suspect a hyrdraulic problem, but it seems to be able to go up 4 inches and get stuck, will go back down up/down/up/down as much as I want...is the consistent ability to go up and down 4 inches a clue about what could be wrong?
Never mind..fixed it...loose hydraulic coupling. Should have checked them all first....
   / Help - loader won't go up JD5410 #3
Yep, that will do it.
If you install a hyd gage, you will catch those kinds of problems.
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
RoGator 844 sprayer (A50490)
RoGator 844...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
