Help - kubota l2850 pto lever - kubota newbie
   / Help - kubota l2850 pto lever - kubota newbie #1
Robo 52
PA
1940 Ford 9N w/5' Ford brushhog; 1993 Ford 3930 w/Howse 5' (bushwhacking) and 6' (field mowing) brushhogs; 1993 Ford 1920 w/front 6' snowplow and rear 6' c7126 New Holland snowblower; 1988 Kubota L2850 w/BF500 FEL and BL4530 backhoe
The nephew wanted to check the oil levels and backed out the pto pivot pin/bolt, and it dropped down into the trans case. Now pto selector lever won't work and the pto is on all the time.
How to get the pin/bolt up and back in place and tightened without cracking open trans case?
   / Help - kubota l2850 pto lever - kubota newbie #2
:welcome:
To the TBN forum Robo52. I am glad that you decided to join us here but I am sure you wished it for better reasons.
I am sure that one of the experts here, of which there are many, will be able to help.
   / Help - kubota l2850 pto lever - kubota newbie #3
You can remove the pto housing and find the bolt with a magnet. Reassembly is a two person job. as you must have someone hold the lever in the right position to align with the pin.
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
197711 (A51244)
197711 (A51244)
2024 Scag V Ride XL (A51573)
2024 Scag V Ride...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
