HELP! JD LT150 w/knock when turned off?
   / HELP! JD LT150 w/knock when turned off? #1
JABLT150
Saco, ME
John Deere LT150
I recently purchased a freshly serviced used John Deere LT150 and mowed the lawn for the first time today cutting roughly 1/2 acre. It starts beautiful and runs smooth, my question is that during the process I turned off the engine a few times and each time the engine (15hp kohler) had a single loud knock and some afterrun or backfire. It would start right back up when I was ready to go again but I'm concerned this is not normal...what should I be looking for?
   / HELP! JD LT150 w/knock when turned off? #2
Did you idle down before shutting the engine off?
In my experience, shutting off from more than an idle will cause a backfire.
Aaron Z
I did idle down but only for a few seconds before turning off. Will allow for more idle down next time to see if that resolves issue. Thanks...
   / HELP! JD LT150 w/knock when turned off? #4
Give it 15-20 seconds at idle before shutting it off. That will also allow the engine to even temperatures out a little before you shut it down.
Always makes me cringe to see someone shut a machine off from full throttle...
Aaron Z
   / HELP! JD LT150 w/knock when turned off? #5
I have an LT 150 and you have to let it hit idle before killing it or it will knock and sound like crap as it shuts off. Normal.
That pretty much describes it. Will allow for more idle down time, should have known better...pretty much the same as the old 12hp wheel horse we owned many years ago...
   / HELP! JD LT150 w/knock when turned off? #7
I know it is not what we were taught from the day we started using gasoline powered equipment, but instead of idling down and then turning the engine off, leave at about three quarters throttle and turn off.
The new engines seems to want to backfire and make strange noises when shut down at idle. The backfire can be so severe as to cause damage to the exhaust system.
   / HELP! JD LT150 w/knock when turned off? #8
Have you tried premium fuel? It sounds like the engine may be dieseling a bit when you shut it down. Super premium fuel has higher octane and should stop the issue, especially if you let the engine idle down and cool off a few moments before shutting off the engine. The newer engines with fuel cutoff solenoids will instantly shut off fuel and cause a lean mixture that may cause backfiring. Autos have used an anti-backfire valve to dump loads of fresh air into the exhaust when decelerating or shutting down so that the fuel will not ignite.
Thanks, it sounds like you have experienced the same issue with the exact model JD. I appreciate everyone's efforts on this forum for taking the time to answer...
UPDATE on LT150 Knocking...
Thanks again for posting suggestions...the answer was as several of you thought...it needs a good 20 seconds to run at minimum idle before turning off. Todays experience was smooth & quiet, and it was a joy mowing the lawn.
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A51039)
Hay Van FL-95 Bale...
2017 Nissan Titan SV (A50323)
2017 Nissan Titan...
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
2000 Safari C-Series 425 40ft Panther Motorhome (A49461)
2000 Safari...
American Sanders EZ-8 Electric Floor Sander (A49461)
American Sanders...
