Help !! JD 5300 Brake Bleed
   / Help !! JD 5300 Brake Bleed #1
ervinedonniebob
Arbovale, WV
96 Agco 6670, 96 Deere 5300, 2 Int 444, 90 Ford 2120, Dresser TD7G Dozer, Dresser 125E Loader, M-B Motor Grader
Hi I rebuilt the brake valve on my 5300. I cant get any pedal now, how ever I am getting fluid @ my bleeders. Any suggestions?
Donnie
   / Help !! JD 5300 Brake Bleed #2
Have you let engine run log enough to fill brake valve reservoir??
Ive let it run for about 45 min
   / Help !! JD 5300 Brake Bleed #4
The following is for the 5x10, should work for you.
1. Connect a clear plastic tube to the left brake bleed screw. Put the other end of tube into a bucket.
NOTE: Two people are needed to bleed the brake system: one to operate the brake pedals and the other to open and close bleed screws.
1. Start the engine and run at slow idle to keep brake valve reservoir full of oil.
2. Pump brake pedal to obtain highest pedal position and hold. Loosen bleed screw 3/4 turn and slowly push on brake pedal. Before brake pedal completes full pedal travel, tighten bleed screw.
3. Let pedal return slowly to the top of its stroke. Continue this operation until the flow of oil in plastic tube is free of air bubbles.
4. When flow of oil is free of air bubbles hold the pedal down and tighten bleed screw.
5. Remove the plastic tube.
6. Repeat brake bleed procedure for the other brake.
You can also go to selectmanuals.com and purchase the tech manual for $29.95
SelectManuals.com
I have the service manual done exactly as it said, Just don't get a full pedal.
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
RoGator RG1100C (A51039)
RoGator RG1100C...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
