Ditto on all filters and fluids.
As for following the manual, I have a DK45se HST and my manual is full of errors including "drain the fluid and run engine for several minutes". It never tells you to add fluid.
In the front of the manual it says to use 15w40 oil. In the maintenance section is says to use 10w30 or 10w40. The pictures don't match my tractor at all even though it is the correct manual for my tractor. It never refers to the hydraulic filter except for non-HST units.
It really tells me a lot about Kioti to sell such an expensive piece of equipment and have such poor documentation. There is no excuse for it.
And, as has been said before, the hydraulic filter is painted on. You'll think it's welded on.
I broke a new plier type oil filter wrench before getting ticked off and driving a screw driver through it and actually bending the shaft on the screw driver before it finally broke loose.
But, the 50 hr is done after about 1/2 day of frustration.
I feel better now.
