Help I'm about to take a maul to my 2420 !
   / Help I'm about to take a maul to my 2420 ! #1
chadwicky
Farmpro 2420
So I had electric issues, which after about 30 fuses I found to be the glow plug.
I replaced the settling bowl, both glow plugs, starter, starter switch and both fuel injectors, took the spring and coupler out of the pump and cleaned that, made sure it was full of oil, cleaned the other coupler and spring on the fuel side. I opened and bled the fuel lines with it running and the stupid thing still has the same issue....it won't start without ether. Then you have to give it an extra couple shots or it kills. In order to keep it running after the ether shot I hold the throttle wide open and it still barely runs. After a while, I take it down the road and it spits, pops and bangs until it's warmed up then it runs a whole lot better. Any ideas on what to do?
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
Kubota M108S (A53317)
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
