Help ID'in some Purlin
   / Help ID'in some Purlin #1
TomPenny
Bronze Member
Royse City Texas
2001 B7500
Help ID\'in some Purlin
I got a bunch of 20 - 24' Purlin and some of it don't know what to use it for. I need to make several awnings.
6" C - Thats easy.
but these....?
4" Channel. these are 20' long.
4" x 4" angle ???
4" x 2" angle
   / Help ID'in some Purlin #2
Re: Help ID\'in some Purlin
Impossible to say without some more information. Did you buy the material from an awning kit company? If so, they should be able to provide you with assembly instructions. If not, then how did you go about getting the material and what did you have in mind in terms of construction?
My Grandpa left me this stuff because he knew I need to build a carport and a patio cover. So I hauled it out here to my place and I'm trying to figure out the best way to use it.
A lot of R panel and poles
probably 15 or more 6" C purlins. 20' I think. Now I know how to use the C Purlins and I'm going to build the carport 16x20 with it. Also the patio cover about the same size. That will use up most of the C purlin
Whats left is a bunch of other pieces like 4" channels.(20')
I'm not sure what the channels are used for. I'd like to build an awning for my barn. I've got 3 stalls all on one side and could take the channel and construct and awning either free standing on four poles or attached to the barn. If could make a rectangle frame with several cross members. Again I wanted to know what this type is typically used for.
I also have dozens of what I call angle pieces. One is 4" x 4" angle 20' long. The other is 2" x 4" angle 20' long.
and last is the Z. I've know what these are for and I don't think I'll need them.
Well it looks like I found my answer. At least part of it. I looked at Wroughtn Harv post about is purlin connectors and I I see now what the 4" channels are for. Just so happens I need to construct a small building too so they will come in handy.
   / Help ID'in some Purlin #5
Welcome to TBN Tom, Give me a call 972 442 3987 and we'll talk. I'm terrible about replying to emails. /forums/images/graemlins/blush.gif /forums/images/graemlins/frown.gif
It looks like you got yourself some treasure there.
And that barn we're building is in Josephine off of 1778 on CR644, can't miss it.
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2015 BMW 320i Sedan (A53117)
2015 BMW 320i...
2025 Mower King SSBM72 (A50123)
2025 Mower King...
