help identify this part?
   / help identify this part? #1
allthumbs23
Bronze Member
WI
Kubota BX2230
New owner of a used machine. I was cleaning under the seat of my BX2230 and found this 3/16" thick piece of pliable rubber. It's about 2 1/2" x 1 3/8" . It was sitting under the gas tank on top of what I am guessing is the transmission case. Not sure if it's part of the machine? Any ideas? Thanks
   / help identify this part? #2
<img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/448528-help-identify-part-img_1370-jpg"/> New owner of a used machine. I was cleaning under the seat of my BX2230 and found this 3/16" thick piece of pliable rubber. It's about 2 1/2" x 1 3/8" . It was sitting under the gas tank on top of what I am guessing is the transmission case. Not sure if it's part of the machine? Any ideas? Thanks
It was probably there to protect the tank rubbing against transmission case.
   / help identify this part? #3
The only thing I could find is if you look at part #K2561-54780 states this is a "U" shaped front cushion bracket for the fuel tank & maybe your piece fits in the middle to cushion the tank. I am not really sure, just a guess.
Thanks alot for looking!
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2019 RBR Venturi 380 (A53473)
2019 RBR Venturi...
2006 Ford F-350 Forestry Dump Truck (A51691)
2006 Ford F-350...
70005 (A51691)
70005 (A51691)
2011 FORD F-450 (A52472)
2011 FORD F-450...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
