Help ID another sickle bar mower
   / Help ID another sickle bar mower #1
BCLoco
Bronze Member
MF 2850E
I hope someone here recognizes this mower, because I've internet searched for an hour now and I'm coming up blank. If anyone knows, that will be amazing, but any and all suggestions are greatly appreciated.
Here's some pics:
This was a piece that was sitting in the fields for who knows how long. I did manage to get it going yesterday. Needs a needle bearing on the crank arm, a belt, and could use all new teeth, but it works! I guess it's not critical to know the manufacturer, but it would sure be nice.
As far as I can tell, the nearest to it seems to be the Ford sickle bar mowers. They have a very similar tube frame, and some other similarities with the belt drive. But the 3-point setup on this one I haven't seen anywhere else. Especially the top link.
One last thing to add: nearly every part has an alphanumeric part number stamped on it that follows the same numbering scheme. Two numbers, a letter, then three more numbers. For example, the belt drive pulley is a two piece, with the parts being stamped 25H499 & 25H500 respectively.
Has anyone seen a manufacturer that uses that part number system? I've had no luck searching any of the part numbers directly.
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2005 MACK GRANITE GU713 DAY CAB (A51222)
2005 MACK GRANITE...
John Deere 331G Compact Track Loader Skid Steer (A50322)
John Deere 331G...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2018 KUBOTA MS-091 TRACTOR (A51243)
2018 KUBOTA MS-091...
2016 Chrysler Town and Country (A50515)
2016 Chrysler Town...
