HELP, I just swapped FELs and sumtins WRONG
   / HELP, I just swapped FELs and sumtins WRONG #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I gpt a 420 loader first, I swapped for the 430. I detached the loader and trailered it back to the dealer, where they swapped it with a brand new 430. They installed the hoses, I kept my original bucket, and mouning frame...
When I put it on operation was slow, and stopped raising at hood height, unless I barely opened the valves. Low HyGard. So I put in nearly two gallons, half sight glass.
At first it was the same. I cycled it several times, but it still isnt right. Dumping especially requires that I barely open the valve, and fast dump is actully a fast roll back.
Do I just need to cycle it more. Also I was at about 1000 rpm (12o'clock on the tach) Do I need to run at 2600 rpm to really get the oil flowing?
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
I will also check with the dealer in AM
   / HELP, I just swapped FELs and sumtins WRONG #2
Certainly sounds like there is a problem. Curious, but you say "fast dump is actually fast roll-back", this sounds as though you have a hose on the wrong connector. Also checking fluid levels according to the manual you should wait at least 1 hour after adding fluid to let it settle and verify level. I can cycle my 430 loader at idle with no problems, granted it doesn't go as fast when running at higher RPMs but you shouldn't have any problems at low RPMs. I would check and verify all connections and lines on the loader frame are going to the appropriate connector, if so contact your dealer and let him know there is a problem.
Thanks Brad,
The troubleshooting section recommended higher rpms for jerky operation. I suspected the swapped lines, as well. This morning, I tried both, and after a little while, it did a lot better. The lines weren't swapped, but swapping them wrong and then right seemed to actually help. I suspect that when the manual states to cycle loader (during checkout) they really meant CYCLE loader. It seems use is fixing the problem
At first, to raise the boom I was actually pulling the stick partially left (rollback and raise) it wouldn't raise alone. Now it is already working better. I also couldn't roll the bucket with the boom raised, now it will. The only function I haven't got, yet is fast dump, it still is fast rollback...
I assume I am getting the air out. Is there somewhere for it to escape, or should I be venting it out (like with the fill cap)?
2014 CATERPILLAR 303.5E CR EXCAVATOR (A51242)
2014 CATERPILLAR...
BHARAT ENTERPRISES PARVEEN ALL PURPOSE PLOW (A51243)
BHARAT ENTERPRISES...
International 133 6 Row Cultivator (A50514)
International 133...
UNUSED FUTURE SKID STEER QUICK ATTACH LAND LEVELER (A51244)
UNUSED FUTURE SKID...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
