HELP! How to get hydrallic filter off for fluid change on 135d
   / HELP! How to get hydrallic filter off for fluid change on 135d #1
ssg510
So I pulled the plug and drained the cream colored hyd fluid out of my little 135d. Went to pull the filter out and undid the three screws off the plate where the metal return line goes back into wher plate bolts back onto the trans and it is like it is welded on. Will not come off. Any trick to get this off that I am missing. Thanks for any help.
   / HELP! How to get hydrallic filter off for fluid change on 135d #2
Spray it down with blaster or Kroil and tap on it to work it loose.
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2018 Infiniti Q50 Sedan (A51694)
2018 Infiniti Q50...
2020 International MV607 2,000 Gallon Water Truck (A51692)
2020 International...
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
