GoodGuy
I'm attaching a picture of the water pump at the house that's giving me trouble. My wife called & said we've got a "bad" leak today so went home early to find the small plug that the guage would normally screw into was leaking, the plug had corroded. For the last couple weeks I had a drip at the suction line so I figured, what the heck, fix everything & I did. I replaced the 2 couplers for the lines from the well as well as the 1/4"npt plug. When I changed the 2 well lines I found a lot of carbon type material which was scattered in chunks to which I cleaned out as best I could. When done, I primed the pump & fired it up, everything good thus far. The pressure was increasing until it got to 25psi & then stopped climbing. I have had it set for 50psi so just figured that it was filling tanks & toilet but after 5 minutes it still had not increased. I thought about a defective guage but the pressure switch is on a diiferent line so if the guage was defective the pressure switch still would have tripped. Hmm, no obvious leaks so I tripped the breaker & let the system stand for 10 minutes, there was no pressure drop so it seems that the system & foot valve are in good shape. I said to myself that it's gotta be the pump so I pulled it apart & did find a chunk of the carbon type material jammed in an impeller so I cleaned it out & everything else seems mint & in great shape. Ok, back together, primed & fired up, looked ok until it got to 25psi & wouldn't climb any more. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif Well, I'm no plumber so time to call for help but it's now after hours so doesn't look like help is available until the morning; hey, wait a minute, I can contact an expert, actually a whole bunch of them on where else but "TBN". Help Guys, what's wrong here, & am I just not seeing something obvious ??? Thanks !!
