Help! Head-spinning! Compact/Sub Compact!
   / Help! Head-spinning! Compact/Sub Compact! #1
cunningstunt
Abbeville, AL
In-Progress
Hello all! Its a pleasure to have read many of the posts on here - I love forums!
Heres the scoop:
-Bought 8acres and a house last year
-Girlfriend owns 53acres that butts up to my 8acres
-Have roughly 3acres of grass around house to mow
-Mowed all last year w/ 31" snapper
-Decided it was time to invest in a manly mower
-found myself about to pay $5k to $7k for a mid range ZT
-saw a BX2680 and got excited - why pay 6k for something that will only ever mow, when i can spend just over twice that and have a multitool!
-Got Kubota to give me an out the door quote for $17,250 - only about $1500 higher than where I want to be
-Found a mahindra eMax HST and drove it - quoted me $17,125 no 0% financing option and absolutely no wiggle room in price from dealer - and way less comfy than the BX
-Went back to Kubota, drove the BX2680, like it but can't quite swallow the price so asked the guy to come down 1500, and I would put 2000 down and finance for 7yrs and he was receptive to at least asking the boss man- waiting to hear back from him today
-Decided to look into Kioti
-$14,550 quote from Kioti in TN for the CS2210 w/loader and deck - he told me theres little difference in performance/hp between 2510 and 2210 CS models
-Called dealer in GA and got a quote for $18,220 on the CK2510 HST w/ loader AND Belly mower and PTO kit - now I am REALLY excited - then he told me its $1100 more when I finance...
If i were going to spend $14,550 for the best valued sub compact, I have a hard time pulling trigger when I can get a MUCH more capable tractor for only a little more money - the CK2510HST w/loader and the belly mower(My initial utility I had in mind)
I WILL find many things to do with a tractor - hauling to hunting camp, planting garden, overhauling my lawn turf, hot composting piles, firewood hauling etc.
Someone help me get out of my head! I want a darn tractor and now I have a hard time buying what I first started looking into - the Sub Comp haha
Any advice here? Any way to get the CK for just 1500cheaper? I dont know how dealer margins work and such...
   / Help! Head-spinning! Compact/Sub Compact! #2
Welcome to TBN.
First thing I'd do is reduce the lawn to not more than 1/2 acre. :D
What will the tractor be doing on the 8+53 acres? Doesn't sound like a subcompact is the right choice.
Size the tractor so it can do the needed tractor work easily, then buy a mower for mowing.
Bruce
   / Help! Head-spinning! Compact/Sub Compact! #3
If you would be using it on the 53 acres as well as your property, I would recommend getting the compact and not the scut. I have a 25 hp scut, the LS mt125 TLB. Very useful and strong machine, there are also scuts from Kioti and Massey that are very capable machines. I have done a tremendous amount of work with mine, but I'm also not on any type of time restrictions. There is a BIG difference stepping up to even the small compacts such as the CK25 series. As stated elsewhere on the forums, you need to decide what you will be doing with the machine both now and in the future. There are pros and cons to both a scut and a compact. Scuts are easier to haul to other sites (I haul mine using my Jeep JK unlimited), they are very maneuverable in tight places, etc... Compacts have higher ground clearance, usually greater pto hp, and are generally stronger and can use larger implements. They can be a challenge to haul elsewhere (bigger truck, bigger trailer). Look at "Bruno's Motorsports" on the web, they sell Massey, LS, and I think Kioti. They list the prices on some. Look at the specs on the different sizes. With today's financing deals, it might be well worth it to "go bigger" for maybe another $50 bucks a month!
   / Help! Head-spinning! Compact/Sub Compact! #4
Welcome to TBN.
Bruce
Agree with bcp! I'm on my 3rd tractor in 18 years as we found that we needed a bigger tractor as we took on larger projects. Also, went with a cab for comfort in the winter and summer. Not that the smaller tractors couldn't do the job, just in our case, we could do it faster with a bigger tractor handling larger implements. Sounds like a compact tractor is a better fit for you. You'll be surprised at all the things that you end up using the tractor for, especially as you get additional implements.
We finish mower approximately 5 acres, in our situation with trees and obstacles, use a Scag commercial mower. Used to use a pull behind mower on the tractors. Dealer let me demo a Scag zero turn mower. Cut our mowing time in half. Definitely for us a dedicated mower is the way to go.
   / Help! Head-spinning! Compact/Sub Compact! #5
are you going to be doing anything with the 53 acres?
Like you we bought 8 acres wooded lot and i purchased a 1705 massey. Its served me well for my tasks. I back filled the house, finish graded the yard, planted grass, landscaped, added stone to our drive. Ive had it for 2 years and have 200 hours on it. OF course we mow with it. Just a handy tool to have. I got a smoking deal on mine but I was also a cash customer. Really you just need to pick the one you like and talk them down if u can. or wait another month to see what the incentives will be. Goodluck
   / Help! Head-spinning! Compact/Sub Compact! #6
Go with a CUT - LS or Mahindra will give you bang for the buck - Kubota is better (I've owned LS and Kubota) but my LS is certainly a good machine for thousands less. Use the savings for attachments you will actually use. Make sure you have an implement that will give you good rear ballest - I leave my backhoe on my G3038 for that purpose, as well as it's always there for me when I need it - when I take it off to put my snowblower on, my 4n1 (very heavy 6' unit) makes it very light on the loaded rear tires and that's with no load in it.
   / Help! Head-spinning! Compact/Sub Compact! #7
Kubota 5660 SUHD
   / Help! Head-spinning! Compact/Sub Compact! #8
What use do you see for a tractor at your hunting camp? With 7" to 9" ground clearance sub-compacts are not very useful on rough ground and cannot traverse many downed tree limbs.
Have you calculated trailer + tractor weight relative to towing potential of your vehicle?
Is it important that new tractor fits within a residential garage? Tractors are theft prone.
I would buy a good quality Zero Turn to mow the three acres of grass around your home. It will mow 50% to 75% faster than a subcompact with a Mid Mount Mower. Or reduce the lawn to 1/2 acre and use the Snapper.
Here is a Mowing Calculator.
LINK: Mowing Calcuator | How many acres can I mow in an hour
If you intend to work on adjacent 53 acres tell us about the property:
Sloped or flat.
Field, Forest or combination.
Crops grown.
   / Help! Head-spinning! Compact/Sub Compact! #9
That seems like a high price for the Kioti CK2510 HST. I have gotten a quote for the exact same setup in east tn for $17,450 on 11/20/17, $17,350 on 1/29/18 and I am still waiting for a better incentive b/c my dealer said "that is still too much and I should wait for kioti to do a free loader or free mower deck incentive." Incentives change again April 1.
Heres the scoop:
   / Help! Head-spinning! Compact/Sub Compact! #10
Also, my dealer priced the CS2210 at $12,990, but that size will not work for me
Unused Delta Crash...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
Kubota RTV-X1100C (A51573)
Kubota RTV-X1100C...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
