Help for a friend
   / Help for a friend #1
VistanTN
middle TN, closest to Beechgrove, then Bell Buckle
A-C 5020-4, Mahindra 6500 4WD, Kubota L4740 HSTC 4WD
Friends of ours just bought 22 acres near us and while I have some opinions of what might be best for them, I wanted to mine TBNers for other input. Property is mostly cleared, with maybe 6 acres in woods/brush. 3-4 acres are mowed as "lawn" with the rest being pasture. Terrain is moderately sloped and quite rocy in many places.
Tom forsees the need for a FEL, 4-5' brush cutter, and something for a finish mower (perhaps a Z-tun dedicated mower or a tractor mid or rear mount). He's not planning on any farming as such (may outlease pasture for grass haying).
My thoughts thus far:
1) On our terrain and with a FEL suggest 4WD is very desirable if not a must.
2) Figure he is on the border between CUT and SCUT leaning toward the smaller CUT's
3) He's probably interested in used, especially if he goes the Z-turn mower choice.
4) I figure his minimum attachment list should include box blade for his .2 mile gravel drive, 4-5' brush cutter, and mid-mount mower (if not the Z-turn) or perhaps a rear mount finish mower.
5) Probably want R-1's as most of the time they do little/no damage to lawns, but when it is wet, they are essential on the hills.
I have a lot of Cat 1 attachments he can borrow for occasional use (PHD, landscape rake, rear blade, sprayer, etc.).
There are a lot of 2WD used machines for sale, but precious few 4WD around here.
Good dealer support is available for Deere, Kubota, Case/IH/NH, Mahindra, and Cub Cadet. Other brands are around, but dealers are farther away.
Thoughts, comments, and input are appreciated.
   / Help for a friend #2
IMHO I think that low 30hp range would be a minimum. That allows for 5ft implements without taxing the tractor. 4WD is a must I think for general needs, I don't use 4WD often but when it's needed, it's needed. R-1's for sure, if the lawn is not an issue. I have R-4's, wish I had R-1's because the tractor will spin quicker with R-4's when pushing or pulling a load. He needs to be patient if looking for a used tractor, with time a good used tractor can be found for a good price. Can't comment of MMM's, don't have one. Good hunting!
   / Help for a friend #3
VistanTN
I think your advise is pretty solid. I would lean towards a CUT in the mid to upper 20's so that he can handle ground engaging attachments such as a box blade as well as carry your 3PH attachments. Jay
New/Unused LandHero Pallet of Binders/Chains (A51573)
New/Unused...
2013 RAM 4500 (A50323)
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
