DFW
Bronze Member
Hi all, I am trying to locate a source for a part for my backhoe. I have the Chinese LW-6 backhoe which I got when I purchased my tractor. During the break in period, I took a pre-emptive strike and greased all of the fittings on the tractor including the BH. At that time my unconscious mind noted someting amiss but did not tell the conscious part. /forums/images/graemlins/confused.gif Well, I found it the other day, seems one of the "pins" that holds the BH stabilizer leg on was missing. I guess when the dealer put the tractor together, they only had 3 of the 4 pins, so they inserted something else to hold it on. /forums/images/graemlins/frown.gif So, I am looking for a source for the "pins". These are the "pins" that go through the ends of the cylinders and BH at the pivot points. They are fairly heavy, hollow inside with a grease fitting on the end to grease these joints. Mine are 35mm in diameter and approximately 145mm in length. So does anyone know what their proper name is and where I might find a source? FYI, I did contact the dealer and they are sending one out, just want a new source.
Thanks in advance,
Thanks in advance,
