Help! Equipment Recommendations
   / Help! Equipment Recommendations #1
Makato
Twin Mtn. NH
Let the discussions begin. Here's my story, I'm originaly from Ohio, living in Texas and moving to New Hampshire this year.
I have a house I bought 4 years ago in Twin Mtn. NH. My property is 85 acres of solid woods surounded by National Forest (big hunter), pine in the lower section and hardwood up the mountain. My drive is aprox. 1500' of crush pack and is a continuous incline to the house with a few twists. The drive cost the original owner 30k to build so its important to maintain. An arial photo looks like a bomb was dropped in the woods to build the house. Hopefully this creates a visual, I'll try to scan a picture next go around.
I've had someone plow in the winter and I go back and forth as much as possible to keep it in order but I always rent some kind of cutter which sucks and takes days.
Now to the questions. I have searched so much till I'm brain dead for the right equipment to maintain long term. I need to be able to keep the sides of the drive cut down, the edge of the run-off ditches cleared, the side hills around the house cut down and I want to be able to begin clearing the undergrowth around the house in the woods to open it up.
Lastly, I want to be able to throw snow to keep the stacking back on the edges. Not much stacking room on the sides of the drive or edges because of the woods. Incline of the drive is my biggest concern.
At first I contemplated an SCUT or a CUT but since I don't have allot of open land, I'm not sure if its a good investment.
Then I though about plowing with my truck and going the 2 wheel tractor route like (BCS) because it has so many attachments. 2 wheel may have traction problems going up in winter. I also thought about an ATV or RTV with a front mower and thrower. The ATV or RTV would be super with all the work up and down the drive and I want to cut some trail for hunting.
One thing to note, lots of rock hidden in the woods under the growth and leaves. The thought is the best equipment right for the job without buying individual bush cutter, blower etc. which is where the BCS came in with all the different attachments.
If you guys can help me get to the right equipment, we can then get to the individual products.
Long post but I thought the detail was important.
Thanks......Makato
   / Help! Equipment Recommendations #2
I'm thinking scut to cut. Perhaps in the 25-30hp range.. 30hp being on the upper limit / large side, as you want this thing to get around int he woods. perhaps 4wd, hydro, and a front end loader. ( optional )
A 4' brush hog.... the 30hp would run a 5'... but keeping with maneuverability, the 4' may be better. Quick connect on the loader a must... if you even get a loader at all.
If you had more open property to maintain, I'd suggest a larger tractor.. but sure sounds like you need something int he 25 hp range to pull a box or scrape blade and a 4' mower, and snow blower.
If you were a NH person.. something like the tc24da would have ben a possible idea if you wanted to look inthat size range.
Just my .02$
   / Help! Equipment Recommendations #3
Have you ever considered something totally unconventional?
What about the Steiner Utilimax 428. 1/2 tractor and 1/2 ATV. Dozens of front mounted implments available, able to climb the slope like a goat, small enough to get in the woods, and then it has its own box to carry some of the woods back to build a nice fire. Rough cutters and finish mowers, snow, garden and all sorts of other implements are all front mounted. It is an amazing piece of equipment. Available with either a 31 or a 34 hp engine. I wish I had one!!!
2 replies, 2 sets of good thoughts and that's why I asked. Now that Steiner looks like an awesome piece of equipment. I'm going to check it out and I'll get back to you. One of the big issues is of course quality and reliability. Not much around in the White Mountain area.
Can you give me a link. I couldn't find a manuf. link and only a dealer in BC. You must have something with those pictures you provided.
   / Help! Equipment Recommendations #5
Sorry, here you go with the link:
Steiner Turf Equipment
My experience when I was shopping was that dealers are spread FAR apart, but they will deliver long distances.
I don't often recommend that particular machine, but your situation seems to scream for it. The Steiner brothers sold their company and it is now owned by Textron (or at least it was) and their eqiuipment is very often used in commercial applications to it is top quality (and unfortunately priced high) equipment, but it is worth every penny of it. I have a Ventrac, which is the company the Steiner brothers opened up a few years after selling Steiner. Ventrac does NOT make a model similar to the machine I recommended. I looked at both Steiner and Ventrac when I was shopping and they are both built like tanks.
The only other semi-similar machine with a front mount implement deck that also has a carry box on the rear end is the Bobcat Toolcat, and those run well into the $30,000 range.
   / Help! Equipment Recommendations #6
Don't know anything about them myself, but your interest in the Steiner [which looks pretty cool to me too] and the elusion to maintanence brings the Power-Trac to mind.
Again, both are out of my realm of experience, but I think PT will train you to do your own maintenance; mabye good maybe bad, but might add another factor to the equation.
Just buy both and give me the one you don't like! /forums/images/graemlins/grin.gif
   / Help! Equipment Recommendations #7
Thanks for the link Bob!
The Texron thing didn't trigger it in my mind, but the web page got some gears turning. If they're built anything like the Jacobsen mowers were [still are?], I don't doubt it's "bullet-proof". /forums/images/graemlins/smile.gif
   / Help! Equipment Recommendations #8
My guess is you will want an ATV just for getting around the property on and pulling a small ATV specific trailer for hauling things around. They do make snow blowers to mount on the front of ATV's but with all the snow up there and the amount of drive a 36" or 48" blower will make snow removal a chore quickly. Besides the unit is heavy and the front suspensions of ATV's are not made to handle equipment like that so the springs will wear out quickly. They are great for hauling a chain saw around and clearing out trails, hauling feed back into a feeder, hauling material to build a stand, and just to have fun on.
I assume the clearing of ditches and side hills you are speaking of is just weeds and maybe some small saplings coming up. For this I would buy a large professional model Sthil weed wacker and you can put a saw blade on it that will cut saplings down up to 1 1/2" diameter. I use one of these on my property in PA and it is the best money I have spent. During the summer I use the string trimmer along the rocky steam bank buildings and house. In the spring when things are starting to get green I use the blade and take it to the thorn bushes and clear the stone rows of saplings and such, even able to reach up and get low hanging limbs. (this is probably a big no no) Another thing I use to clear out brushy areas and stone rows is spray on Brush-B-Gone in the spring.
Then you are going to want a tractor for blowing snow and general heavy duty work of moving stumps, logs, stones and things. But I don't have the experience on any of the new tractors for doing this stuff so I will let others that may be better qualified answer that for you.
I will say that the short time I have been on here the general consences is to buy new compact tractors. This is great but IMO there are lots of used older tractors out there that will perform very good for most projects allot of us do. Don't discount a 2wd tractor either, with weight and a set of chains they can be very good at moving snow and pulling.
Now with all of that said a nice new 4wd tractor is pretty slick and we all want to have one someday! /forums/images/graemlins/laugh.gif If it is in the budget go for it, if you aren't sure buy used and in a couple of years if you decide new is better your loss will be very little or none at all because the old tractors hold value well if you buy smart.
   / Help! Equipment Recommendations #9
Spiffy, about a year ago I had two threads running on TBN that both went over 12 pages of posts. I was searching for the BEST garden tractor to mow with. At that time I was mildly familar with Power Trac and knew nothing of Steiner or Ventrac.
To make a long story short I played with everything and I did it on my property. Ventrac won, but only because I was looking for the best MOWING machine for slopes and already had access to 2 compact tractors and lots of implements. Had my criteria been different, I could very easily have been talked into a Steiner 428 or one of the diesel Power Tracs. But I honestly could not have fit a 428 into the garage at the time I was shopping.
As I now have a bit more property to mow and as I am now building another garage I might have to trade up the Ventrac??? The lovely Mrs_Bob is constantly complaining about needing to tote stuff around and the 428 would solve that . . . but still might get me a frying pan smacked upside my head if one showed up in the driveway next time she goes out of town to visit her mom /forums/images/graemlins/blush.gif
As for Jacobson, yes they are still around. I think they are mostly now professional grade and sold to golf courses. There is a Jacobson version of the 428 but from what I could tell when I looked at all this stuff, the only difference was the paint.
Thanks Bob, I kept searching and it looks like Jacobson bought out Steiner and Textron owns it all. That probably makes things a little easier since Jacobson dealers probably have good access. I'm looking at the web site with great interest.
They're definitely proud given the price of the unit and attachments. I need to find more detail as the info is limited (weight, clearance etc.).
The snowthrower doesn't really state if it is a single or 2 stage and one thing is I'm somewhat concerned about (belt) driven. I need to give them a call and see if there is more detail available.
I'm looking at some Power Trac equipment also. Although its not part ATV, the attachment availability and pricing is interesting.
Thanks....
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
Ford 18in. Stock Rims (A53117)
Ford 18in. Stock...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2012 Diamond Cargo Enclosed 24FT T/A Cargo Trailer (A51694)
2012 Diamond Cargo...
1995 GMC CHIPPER/BUCKET TRUCK (A53426)
1995 GMC...
Multiquip GA9.7HEA 9700W Generator (A51691)
Multiquip GA9.7HEA...
