Oil & Fuel HELP - Diesel Drain or not (Sta-Bil)
   / HELP - Diesel Drain or not (Sta-Bil) #1
bes06
Virginia
Kubota L3400
My neighbor got me feeling guilty that I hadn't been adding a stabilizer to my deisel fuel so I went out and bought Sta-bil (red fluid in plastic bottle). I added it to all by gas engines and didn't think it would hurt to add the appropriate amount that went with 5 gallons of diesel to my tractor. I mixed it in the diesel can and poured into tractor to get a full tank. I went to my small engine repair class and he said you don't add that to diesel. Should I drain it out now or will the one mixing not hurt it? How is the best way to drain it? I can't seem to locate the manual right now. Is there a drain plug below somewhere for easy draining? Thoughts/advice from smarter, knowledgeable, tractor folks would be much appreciated. Thanks
   / HELP - Diesel Drain or not (Sta-Bil) #2
I wouldn't think that it would hurt anything I would just run it. Isn't it 2.5oz. of Stable to 5gal. of gas. That little bit shouldn't hurt a thing. Just top the tank off with diesel.
   / HELP - Diesel Drain or not (Sta-Bil) #3
Did the small engine "professor" say why Sta-Bil shouldn't be added to diesel? My bottle of Sta-Bil also says it can be used in diesel and I can't imagine that the very low concentration in a tank of diesel would hurt anything. Personally I use Sta-Bil for gasoline and Power Service for my diesel.
   / HELP - Diesel Drain or not (Sta-Bil) #4
Same here
   / HELP - Diesel Drain or not (Sta-Bil) #5
On the back of my bottle it says for all Gas and Diesel engines.
   / HELP - Diesel Drain or not (Sta-Bil) #6
I wouldn't worry about it. Just run it.
   / HELP - Diesel Drain or not (Sta-Bil) #7
By the way ... welcome to TBN!
   / HELP - Diesel Drain or not (Sta-Bil) #9
no problem just run it bottle says for gas or diesel.if your looking for cold weather protection I'd go with a diesel additive like Howe's or your favorite next time
Thanks everyone for your thoughts. The bottle I have is clear with a red fluid in it. It does not mention diesel. I will take your advice and run it until it is gone and not make that mistake again. Thanks again.
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
CASE 580M SERIES II TURBO BACKHOE (A51242)
CASE 580M SERIES...
2016 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
