SARG
Platinum Member
- Joined
- Aug 29, 2009
- Messages
- 813
- Location
- Upstate New York
- Tractor
- NH T1030- NH T1530 - 49G Brockway
I have a Husqvarna 2354GXLS tractor with a Briggs 23 hp Vanguard engine. It has under 200 hours on it and I've not had any engine issues until today.
After mowing heavy grass for about two hours I was headed back to the garage and the engine started to stumble and misfire. It will idle OK but as soon as you put any load on the motor it stumbles. I went through the normal checks and the air filter and fuel filter were like new .... I changed both maybe a month ago.
I did find that "both" spark plugs had a very heavy soot deposit. These plugs have less than five hours on them. I installed two more new plugs and the engine stumbles under load just as before. I did check to be sure the choke was totally off.
Now I'm scratching my head. If it was a valve problem then only one cylinder would be fouled. It was 85 degrees today so I'm considering it might be heat related and something on the ignition system is croaking.
Anyone give me some ideas ?
