Help Diagnosing a Yanmar 2010d problem
   / Help Diagnosing a Yanmar 2010d problem #1
smithboy
Carrollton, GA
Yanmar 2010d, John Deere 2640, Deutz Allis 6250
First of all, I have used this forum several times to find useful info about my tractors and am very appreciative of the knowledge here. However, this is my first post. I have a yanmar 2010d (4wd) that i use to do light work in and around a couple of rental properties. I was bush-hogging an overgrown 2 acre plot and near the end of the job, I hit a couple of sweetgum saplings that caused the engine to bog down a bit, and then both the brush cutter and the forward drive became inoperable. The engine runs fine, but no drive forward or reverse and only a little of the engine's power is being transferred to the rear pto. The bush-hog barely spins at all. THe transmission is a shuttle shift. Did i burn up my clutch?
   / Help Diagnosing a Yanmar 2010d problem #2
As long as there was no metallic crack or grinding sound the clutch is where I would start. Since neither the drive nor the pto operate but you still get a little spin at the pto that also points to the clutch. Does your machine have a clutch pedal you use to engage and disenage the pto?
It only has the one clutch pedal that operates both the transmission and the PTO. I don't think it's a two stage clutch and I also don't have a separate pedal for the PTO. I didn't hear a loud crack, grinding or anything like that. It really went from pulling and cutting to not pulling and not cutting in a matter of a second or two. By the way, I said earlier that it was a shuttle shift, but I think the correct term is powershift, if that makes any difference at all.
   / Help Diagnosing a Yanmar 2010d problem #4
Look for the parts diagrams for your machine. Yanmar's website or Messicks.com would be a good place to start. If as I think your shuttle transmission is driven through a conventional clutch at the flywheel then that is likely the clutch that has failed. Some machines have an inspection/adjustment port on the bellhousing. That might give you some confirmation before you split it.
Toro ProCore 864 Series Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
2013 BMW 528i Sedan (A50324)
2013 BMW 528i...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
UNUSED AGT QUICK ATTACH HYD HAMMER (A51244)
UNUSED AGT QUICK...
Takeuchi TB260 (A50120)
Takeuchi TB260...
