rbcsaver
I bought my B7510 new this year after we bought our new homw with 6.5 acres. Recently I fabricated mounts nd installed 2 55W Halogen "Blazer" light on the ROPS. They are connected to the light switch via a splice in the rear running lights. I had to increase the fuse to 15W after the factory 10 blew. Otherwise, no probelms. This past weekend I fabricated another mount and installed another 55W Halogen rear work light into the same head/rear light wiring, but with a toggle off/on switch.
Tonight, after working in the dang early winter/rain mud, with my Fel, then idling while I washed the mud off, I went to install the front plow for the impending storm. It would not start without a external jump.
I retrieved my volt meter and at full throttle, WITHOUT ANY LIGHTS after 15 mins, the reading at the battery terminals is 0
(zero) volts. A car usuallly is about +- 14 volts.
What DA voltage should I be reading without any lights at full throttle (or even idle). Is there a problem with my electrical charging/battery system? Do I need a larger, if it is available, generator? Is there a difference, for example be tweeen the generator for a 7510 of larger models. Ilooked on the Kubota wesite, but could not find any info.
regards,
Steve
regards,
Steve
