Help Control Box Trouble
   / Help Control Box Trouble #1
Whitey
Slippery Rock, Pennsylvania
Kabota B21 TLB
OK, I have an update on my control lever for my JD 7 backhoe and my woes have gotten bigger :eek: I took the control box shields off and peered into the heart of the matter and saw the folllowing;
Operate outrigger on right side......leak at the base of the spool??
Operate control arm on right side....leak at the base of the spool??
Wrong terminology?? I don't know.... but what I do know is that there is hydro fluid comming from two 1 1/8" hex plugs. I believe that they will come out and there is a o-ring or something to seal it but how does one loosen these buggers>:confused: The socket will not fit between the housing and over the hex plug!
Do I need to take all my hoses off and use an open ended wrench? If I go this far should I be rebuilding the rest??
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
Ford Tractor (A50120)
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
JOHN DEERE Z997R LOT NUMBER 242 (A53084)
JOHN DEERE Z997R...
2018 HINO 195 16FT BOX TRUCK (A52576)
2018 HINO 195 16FT...
