Help choosing a welder
   / Help choosing a welder #1
polo1665
Veteran Member
Ohio
Branson 3510H, John Deere X750
My girlfriend and I recently purchased a beautiful home on 33 acres about 18 miles east of Canton, Ohio. Since then I have bought my first tractor and have been scouring the pages of TBN for useful advice to help me on my way. Now I need a little help with a purchase.
I have a feeling I will be in need of a welder at some point. Whether to weld chain hooks on the FEL, repair implements, or for fabrication of needed items. I have never welded so I plan on keeping it simple. I've narrowed my choice down to either a 225 or 235 volt AC stick welder. Here's my question. Which brand? Does it matter as long as they are well known brands?
Thanks for any help you can give me
Mark
   / Help choosing a welder #2
go with one of the big three in this order
miller
hobart
lincoln
good luck with your welding projects!
   / Help choosing a welder #3
Welders are long term ownership tools. Don't scrimp as you will go broke taking yoga classes to get limber enough to kick your own behind. Buy once and buy for the long term. It winds up costing less overall.
(at least that's how I rationalize it!)
jb
   / Help choosing a welder #4
jb
"JB" I have heard from others, including my son, that one can lay a better bead with a DC welder.....is that a true statement? If not, why is one better than the other??
LEE
   / Help choosing a welder #5
You might as well just get the AC/DC stick to be able to.
1. weld easier on DC
2. have more choices for whatever your welding.
   / Help choosing a welder #6
I'd stick with the brands listed and watch Craigslist, around here an old Lincoln 'tombstone' will show up for $100-150 every now and then. You can always sell it for what you paid for it if something better comes along.
Charles
   / Help choosing a welder #7
Yep, listen to these guys. I've a old Lincoln Idealiarc 250 AC-DC stick machine. I keep all my junk implents moving with it. I like 6011 fast freeze rod for most everything I do. Get a little 4-1/2 grinder (get two if you buy Harbor Freight stuff one for a 3" knotted wire cup wheel) and a pnuematic needle scaler really helps to clean things up. A decent size air compressor will be needed also (you sure you wanna do this, I mean the dollar bills are just gonna fly by). Your probably gonna need a Oxy/acetlene outfit also and frequent trips to the scrap metal/recyclers for material and trip to the TSC store. A cheap Harbor Freight HVLP paint gun to pretty things up. Soon you'll enjoy seein' what you can make move again. A shed or shop to keep all the tools in and, I almost forgot, your gonna need a bunch of time (get this in the 55 gallon drum size 'cause you'll always be runnin' out.) bjr
   / Help choosing a welder #8
I am just learning to weld myself. I have a Lincoln Electric 225AC that I bought cheap from another TBNer. I have been taking a class at the local comm. college (Highly Recommended). There, I use a Lincoln Electric Inverter 275S - a DC machine that also does TIG (I think). The DC welder is nicer.
Bear in mind that most of those $100 tombstones are AC only. Look for one that is AC/DC. The 7018 electrode (commonly used for many welds) is difficult to use on AC. There is a 7018 made just for AC welding, though, so there are alternatives if you end up with an AC machine.
Oh, here are a couple of welding forums you might be interested in:
WeldingWeb™ - Professional Welding Forum - Powered by vBulletin
Weld Talk Message Boards - Powered by vBulletin
   / Help choosing a welder #9
I have a hobart stickmate XL235AC
It's a nice unit... can weld at 90-100A and 100% duty cycle. You can turn it up and use a larger electrode and weld 1/2" in a single pass.. or chamfer with it if needed.
For working with thick materials.. it's hard to beat a 200-400$ stick welder... Migs work thick metals fine.. but the machines that do the same thickness can be 5x the price. For that $$ I can chip a little slag off my work piece.
DO get a good set of long gloves, and a welding jacket or at least an apron.. I reccomend a long sleave weld jacket, and shoe chaps unless you wear boots.
Get a helmet you are comfortable with.. Some like the flip down.. some like auto darkening.. if you get flip down.. do for the full face visor.
Get a 4" angle grinder, a chipping hammer, a wire brush. and a tube to hold your rods nice and dry. A couple different vice grips made for welding and fab work.. a metal marking crayon or soapstone/holder.. and choose the rod type for your machine and work piece.
For instance.. 6011 is good deep penetration, fine on AC, makes an ugle weld... 6013 onthe other hand makes a very nice looking weld.. almost that of a mig.. but doesn't bite near as deep as the 6011.
In situations where you can't prep the metal adequately... like an emergency repar to a thick piece of rusty/painted metal.. lots of amps and an 6011 rod on an old cracker box will get-er done. Even in wind or rain where a mig might not stand up as well.
soundguy
Mark
   / Help choosing a welder #10
Forgot to add.. a good chop saw or bandsaw makes fabrication MUCH easier... torches.. even cheap mapp or propane torches also help when forming metal.
soundguy
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2020 KUBOTA RTV...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2019 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2019 TOP HAT...
John Deere (A50322)
John Deere (A50322)
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
