Price Check help: BX2750D with no chain or sprocket work $600 ?
   / help: BX2750D with no chain or sprocket work $600 ? #1
lawlopez
New Boson, NH
JD X450, Kubota BX23
Local owner saw my craigslist add, the story:
chain & sprockets blew up, parts were going to take 6 weeks, he bought a new BX2750D.
He replaced the Auger and bearing.
He is asking for $600 (for just the BX2750D not the BX2751 and BX2752 that I would need to front mount).
Does this sound like something I want to get into ?
I'll stil have my Toyota pickup & plow.
I was originally thinking of shelling out the money for the front mount parts but now I'm thinking I could just run it rear mount for a while.
I'm seeing him at 2:30PM.
The chain and sprockets are about $ 120 according to Chappel Tractor.
Well, it looked like it was in pretty good shape so I'm getting it.
   / help: BX2750D with no chain or sprocket work $600 ? #3
Kubota also sells those parts as a component, assembled and ready to bolt right in.
Your other post implies you have decided against the buy, but you should consider buying the component if you do move forward.
I got the $600 plow.
It's beat up, but everything seems to turn properly.
The bearings seem like they are in good shape.
002 70060-01424 DRIVE SHAFT WITH SPR 1 0 (H40C11) $39.60
012 70060-01274 SPROCKET 1 0 (H40B32) $29.25
Well that's not so bad.
Chain is OK, sprockets are well worn.
Now all I need is the rest of the parts.
BX2751, BX2752, ...
ordered the BX2751 and BX2752 from Chappell tractor in Milford.
Prices seemed to be pretty good.
It turns out I have a BX2750 and need:
2 70060-03889 DRIVESHAFT W/SPROCKET $44.25
12 70060-03890 SPROCKET H40B30 $26.40
$70.65
Not a BX2750D which needs:
$ 68.85
for whatever that is worth.
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
2016 Crae Garbage Truck (A51692)
2016 Crae Garbage...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
