3-Point Hitch Help! Broke tang where lift arm attaches to tractor
   / Help! Broke tang where lift arm attaches to tractor #1
HankC
Bronze Member
Mass.
IS there any way to repair or reconfigure the attachment point of the lift arm where it attaches to the tractor.
I have a Jinma 2430 tractor, was doing some tilling when I noticed the tiller was skewed. Checked the lift arm and found it was not attached to the tractor. Closer inspection revealed that the retaining pin was gone and the cast iron tang (that holds the pin on one side) was broken off. Is there anyway to repair this without replacing the complete cast iron assembly?
Thanks for any advice,
-Hank
   / Help! Broke tang where lift arm attaches to tractor #2
To get a good answer, post a picture of it. From what I picture in my mind, this is going to get pretty involved, as in requiring some machining. Fair amount of stress in this area.
Thanks for the reply! Unfortunately the tractor is 100 miles away so I can't take a pic right now but I'll try to get a diagram.
Thanks Tommy, that's what I kind of figured. I was just hoping that someone had a similar experience and had some fix (not hoping that anyone would break their tractor).
Any rough idea whet the casting would cost? It's the outer boss that broke and it's on the rear wheel axle housing.
Looks like the pin got loose and backed out stressing the boss.
Hank
Tommy is that for the complete housing and internals or just the empty cast iron housing?
Just want to scope out the work load and difficulty of changing it. Nice if it was just a simple bolt-off, bolt-on project.
Hank
   / Help! Broke tang where lift arm attaches to tractor #8
Is the part that you broke on your tractor the 'tab' that is in the the lower middle of the image in the link? If so, I see some potential here for a fabricated bolt on solution.
Yes it's "tab" that broke. I would imagine one could fabricate a bolt-on solution, just hoping that someone already had . Will bring the tractor home soon, it'll give me a better opportunity to evaluate all my options.
   / Help! Broke tang where lift arm attaches to tractor #10
Yeah, I think if you just stare at it for a while a bolt on solution will make sense. At this point, what do have to lose? It would sure beat having to replace the casting! Some people might say you could weld that but I'd recommend not going that route.
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
70007 (A51691)
70007 (A51691)
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
1996 Trailmobile 53 ft. Dry Van Trailer (A53117)
1996 Trailmobile...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
