HELP AGAIN SICKLE BAR REMOVAL
   / HELP AGAIN SICKLE BAR REMOVAL #1
newbee83
Bronze Member
Case 870 Agri-King
:confused:I am new to the whole haying ordeal so I am still learning my equipment, anyway it seems its not cutting as well as it did so I want to know a few things:
1. Am I better off buying new teeth or sharpening the old ones?
2. What is the best technique to use to sharpen the teeth
3. Can I and how do I remove the sickle bar as a whole?
The haybine is a NH 477
Thank You for all the help
   / HELP AGAIN SICKLE BAR REMOVAL #2
Pull out the drive locking pin on the gearbox end and then we put a small chain around the end of the bar and give it a couple bumps with the ATV to pull it out. Sometimes, you get lucky and it will slide out by hand. Easier to sharpen when out. Can be sharpened while in,however, those pickup tines get into my back get to be a PITB. Ken Sweet
   / HELP AGAIN SICKLE BAR REMOVAL #3
Just remember to keep your fingers away from places where they could get cut.:thumbsup:
   / HELP AGAIN SICKLE BAR REMOVAL #4
To get from under the machine, we always use a small short chain around the bar head and pull the chain, with a quick snap. Ken Sweet
   / HELP AGAIN SICKLE BAR REMOVAL #5
Remove the blade as Ken said. Put some lubricant on the blade and turn the mower by hand before you start, that will allow the blade to move easier. My rule of thumb is as long as I have decent serations on the blade I can sharpen the top edge and it will cut well. If the seration is gone then it is better to replace the section. What is the conditon of the mower guards, they have a serrated edge that mates to the bottom of the sections which can also affect the cutting? There is no way to sharpen those. Having the blade out also allows you to check for loose sections on the blade that can either be tightened or replaced. I am assuming you are talking about a single action sickle mower which is the older style. Willie Jones
Yes I have an older 477 haybine, it is a single bar.It seems like half the teeth have the serrated edges missing..I should replace these or sharpen them??Also the look to be rivited on can I replace them with bolt and nuts with out much trouble? Thanks again guys.
You say unhook the pin that holds the bar, mine has a nut and bolt? IS that what you mean to take off? and thats all that holds the whole bare? And then pull from the oppisite side to get it out? Thanks
John Deere 980 Field Cultivator (A50514)
John Deere 980...
Allied 760 Loader (A50515)
Allied 760 Loader...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2002 Ford Ranger XL (A50323)
2002 Ford Ranger...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
