Help/advice on used 755
   / Help/advice on used 755 #1
fwchiro
Central NC
Iseki 1910, Kubota B7100HST-E
(Posted in the general forum firrst...sorry, not sure which was appropriate)
Hey fellow TBNers,
Been lurking and learning here for a while trying to make a decision on a first tractor. Looking to do the following:
- turn an acre of pasture into a lawn
- fence in several acres
- start a garden (maybe 1/2 acre this year)
- 1-2 acres bush hogging
- maintain 150' gravel drive
Been looking in the 20hp range, with a FEL and hoping for 4wd although I have a very flat lot so 4wd is the lowest priority of the 3 criteria. Had a verbal agreement to buy a yanmar ym2001 2wd with an fel but the guy had to back out so I have been scouring craigslist and come across this ad:
John Deere tractor
It's ain't pretty, but a tool doesn't have to be! I have talked to the guy and he says hydraulics are strong and it does smoke some (will check air filters), but I hope to get some advice from those more familiar with these tractors. I should be able to get up there and look at this weekend and just wanted to know more about what to look for.
   / Help/advice on used 755 #2
Sorry fwchiro I did not see your post sooner. That listing is no longer there, but I think you are looking in right direction. For your size lot and what you want to do. The 55 series tractors are good solid machines. I would try to find a machine with 4 wheel drive if possible. It does make loader work so much easier.
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
UNUSED FUTURE J5T TON 36" HYD THUMB CLAMP (A51248)
UNUSED FUTURE J5T...
2011 CATERPILLAR 12M MOTORGRADER (A51246)
2011 CATERPILLAR...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
