Help! 4300 won't turn off!
   / Help! 4300 won't turn off! #1
arkvet
Arkansas
JD 4300 HST 4WD
Its 7am and I'm standing next to my 4300 that I used to disk a food plot this am. Turned the key to the left and it keeps running. Scratching my head a bit I decide to just turn the pto on and get off the seat. That will at least temporarily fix it right. Nope. None of the safety shut offs work. With an old push mower I know the ole screw driver kill trick... With this?????
#1 how do I turn it off now?
#2 what's the deal???
Someone do me a favor and text meif you know a quick answer. I'm gonna keep trying to figure out how to shut her off.
Thanks.
Brent 870-335-0422 (ok to text that you've replied to topic)
   / Help! 4300 won't turn off! #2
can you turn the fuel off?
Uhhh yeah. Guess under the pressure that one didn't cross my mind. That'll kill her soon. Thanks!
By the way now gauges are not working. Got some issues to look at
   / Help! 4300 won't turn off! #4
Your fuel shut-off solenoid is stuck. Personally I would NOT shut the fuel off. It is a major PITA to bleed it out. Just try stalling it. IE: put it in gear in high range at idle.
   / Help! 4300 won't turn off! #5
I agree it sounds like a stuck solenoid, but the 4300 is self bleeding so bleeding later should not be a problem. Also it is an HST so kinda hard to stall it.
   / Help! 4300 won't turn off! #6
Ok. I didnt know if it was a self bleeder or not. Were ALL the 4300's HST, Cause I didnt see it mentioned??
Edit....I see HST in his Avitar now :confused2:
   / Help! 4300 won't turn off! #7
Can you move the fuel solenoid manually? Some you can. It sounds to me like you have possibly a blown fuse as your gauges do not work also. Try to kill the tractor by smothering it with a large rag in the air intake. Find and fix the electrical problem that is preventing the fuel solenoid operation, and likely is related to the gauge operation.
James K0UA
   / Help! 4300 won't turn off! #8
That reminds me....
On my L3400, ON the injector pump, there is a manual fuel kill lever also. Similar to what is found on older tractors that had a manual fuel kill (like a choke lever). This lever on MY pump is like what a manual cable would have hooked to.
I know there was a thread on here awhile back about what that lever did cause the manual makes no mention of it.
Started pulling the black square solenoids in the fuse box one at a time. I didn't have my manual handy. The one in the middle killed it when I put it back in. Sounds like I need to pull all the fuses and black boxes out of the panel and clean some connections.
Thanks!
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
