Help: 4115 getting close--input on mmm 60" v 72"
   / Help: 4115 getting close--input on mmm 60" v 72" #1
EldoNixon
Bronze Member
Bacon Hill (Saratoga), NY
BX23 TLB
Help: 4115 getting close--input on mmm 60\" v 72\"
I spent the weekend looking at all of my finalists, and think the 4115 is the best fit for my needs. Kubota BX22 is too small, 7500 and larger use rolling decks, the Kioti can't use MMM w/BH, etc. Nothing is perfect, but the 4115 seems to fit the majority of my needs and still give some room for error. I want the smallest (lightest) tracor to handle my 3pt needs, but I don't want to give up suspended mmm. I should buy a 4110, but I'd like the extra hp of 4115. I don't want to go to 4210 (too big and heavy.) I plan to use a BH to install a septic system, etc and to use a tiller pretty seriously (about an acre).
I'm thinking 4115, 410 loader (53"bucket w/toothbar & pallet fforks), 60" mmm w/suspension lock-up & mulching deck, tiller (ideas, 655?), back blade, PH digger, block heater, and eventually 46 BH. I want to try and get it all at once to take advantage of the low financeing (and not have to get my wife's approval in the future.) I saw in another post that the 46 loader "should" be compatible with MMM. Any more info?
My concern w/ 60" deck is that it doesn't extend much beyond the tractor. Can you get close w/this? I have a lot of mature (36"-48" diameter) maples to trim around. My current deck extends about 6-10 inches beyond on both sides. It's great for getting close under the hastas and lillies bordering our trees, and walks. Does anyone have the 72". How well does is cut? My land is rolling, will it scalp a lot more than the 60"? I would sure like the extra foot. Plus, I think it will still fit everywhere I need to go. I'm really worried about scalping. I also mow my field w/my mmm. I'm sure that the 4115 will have enough hp for the 72" through long grass--only about 6-7" when I cut it now. Mowing is very important to me. I have a B&B and i need to finish mow about 3 acres once to twice per week.
The dealer has a 4115 he wants to move. So I'll see how tempting he can make it. I know that the new decks are green, this one has a yellow deck, even though it's new. Are there any differences on the new green deck other thant colour? I'm not talking 7 iron, they only fit 4210+.
Also it has a fixed rops, would it be expensive to swich to folding? Should be the dealer just swapping, right? The in-stock unit has turfs, but I'm worried that they won't let me till. But overall, I think turfs will work best for me. I guess I can always get a set of ags if I need them, or could I use chains w/ the turfs if I need more traction?
I'd appreciate any input. Thanks
   / Help: 4115 getting close--input on mmm 60" v 72" #2
Re: Help: 4115 getting close--input on mmm 60\" v 72\"
Eldo,
I'll offer my opinion on the 2 items I have experience with.
1. Folding Rops--I would really have to trim my trees up high in order to mow with the ROPS up. Depending on the type of trees you are mowing around, the folding ROPS might be the only way to go.
2. Tilling with Turfs. I recently used my 4010 and a 50 inch tiller to turn an old pasture into a space that could be mowed with the mmm. While I did need 4wd to do it, traction was not a problem with the turfs. If you're doing a lot of mowing (and it sounds like you will be) then turfs would probably be the way to go.
Good Luck
Bob
   / Help: 4115 getting close--input on mmm 60" v 72" #3
I can't answer your scalp question as yet. I'm sure it increases the chances. All depends on the waves in your cutting surface.
I have a 60" MMM with my 4310. Used it for one summer and then took on more mowing. It also just spans the rear tires. I wanted to go with the 72 to increase my mowing width but also to be a able to reach out or under things to get close to things. Right now I have to use care as the tractor is as close as the edge of the deck.
I called last fall and asked about trading up to the 72. It was $1100 to trade. Had I gotten the 72 with the 4310 it would have been 500 more at that time. I made my choice of the 60" coming from a JD 445 L&G. It had a 54" deck and going to the 60 seemed like a huge step. Once I got the 4310 I started to think the 72 would have fit my needs much better.
I'm in the process of getting the 72" MMM. If the 72" is offered on the 4115 the only question would be how well it might perform in the higher grass. Other owners might comment.
As a side note. I first looked at the 4115 thinking the 4210 was too large for me as well. The actual price difference was not all that much if I recall. Once I decided to move up to the 4210 I compared and ended up with the 4310. It felt too big at first but I sure did get used to it.
Craig
Thanks guys. That makes me feel a lot better about the turfs. I really think they will be the best choice overall, and I certainly don't mind using the 4wd. Heck, that's part of the reason I want to update my JD 400.
As for the deck, I expect I should go with the 72". I have a 60" deck now on my L&G tractor and it still takes me 5 hours to mow.
As far as upgrading to the 4210, i should go ahead and look at the 4710 the way I keep moving myself up. 3 years ago I thought my L&G tractor would be all I need, but now I "need" a loader and backhoe and bigger tractr. It's funny how easy it is to move yourself up. But, I really think I want to stay on the small frame. The 4210 is about 900lbs heavier, as I remember. I have two septic systems and leachfields that I mow over now, and I need to add a third. So I really want to stay as light as possible. That's what appeals to me about the 4115.
Thanks for your input. This is a really big decision for me. I've been agonizing over it for 2 years. In dact, I almost pulled the trigger on the BX until I paid a farmer to put in my garden this year. When I saw how easily he did it with a bigger tractor it really got me thinking.
   / Help: 4115 getting close--input on mmm 60" v 72" #5
Yeah, you could get up to the 4710, if you keep stepping up!
From your posts, I think you are going about everything perfectly. I think the 4115 with 72" deck will do very well for you. As powerful as you can get in the small size.
The 46 sounds like it will be very nice, the bigger hoes all work with the mmm, If they say the 46 will, it should be great.
I'm glad to know that someone thinks that I make sense. I should have my wife read this... /forums/images/graemlins/smirk.gif
But can I do stunts and jump hay bales with the 4115 like you can?
   / Help: 4115 getting close--input on mmm 60" v 72" #7
The 72" mmm is EVERY BIT of what the 4115 can turn. That said, as long as you are not trying to mow very tall grass, you should be fine. You will also find that the 72" mmm does not allow you much room to maneuver and is more suited to wide open spaces. I moderate amount of trimming can be done. I have found that my John Deere F525 can cut circles around my 4410 in the yard and don't even bother to use it for that. I use the mmm to cut open pasture area that I have VERY CAREFULLY walked and spents MANY hours removing rocks. If you have any extensive amount of trimming or obstacles where you mow, you will find the 72" mmm a RPITA. The 72" mmm is a good piece of equipment for what is what designed for which is cutting large open areas with not much trimming. I cut about 4 acres with the F525 and the rest I cut with the 4410 which is about 7 acres. The F525 is EXTREMELY manueverable with an off set front 48" mower. Not nearly as big as the 72" mmm but can cut more and cut it faster because of the tighter spaces it can get into and the nearly zero turn radius. Just wanted you to understand what you are getting. You will find that professional mowers cut with a 60" mower for these reasons. The 4115 is a nice tractor and will do what you are wanting but with the 72" mmm it will not be as athletic as you might think. /forums/images/graemlins/wink.gif
   / Help: 4115 getting close--input on mmm 60" v 72" #8
I've got to weigh in on this one. I've had my 72" mmm on my 4410 since April and have probable mowed once a week every week ever since. I have actually bogged down the 4410 in heavy grass and I think you will be way over matched with a 4115. Also, if you mow anything more than plain flat grass areas you will scalp and scalp and scalp again. This deck is so heavy the anti-scalp wheels actually scalp.
Don't get me wrong, I love the cut and speed of my 72" but at times I feel like my 4410 is right on the edge.
Think about it.
   / Help: 4115 getting close--input on mmm 60" v 72" #9
If your mmm is scalping that much you don't have it adjusted properly. I have stalled my mmm out 1 time and that was my fault for not seeing a tree root. Mind you I said stalled the mower out. The mower stopped turning completely but the engine just kept turning and sounded like it was under a lot heavier load but maintained rpm (this only occured for less than a few seconds before I hit the pto knob as well as noting the belt smoke) If you are bogging down the mmm, you are cutting vegetation that is waaaaay too much for it. It is NOT a rotary cutter. The mid pto is not designed for that much of a load on it. You should either raise the deck height and then make a second pass after lowering the deck height or use a rotary cutter.
   / Help: 4115 getting close--input on mmm 60" v 72" #10
I have adjusted the mower correctly. By the book. The only way to prevent scalping with a deck this heavy is to buldoze the fields level or cut your grass at 6 inches. As soon as the nose roller hits the ground you have a plough. The deck is way too heavy for the roller to roll.
The poster wants to use this deck to mow his "yard". His wife will come out and say "Honey what are all those streaks in the yard"
The answer is exposed top soil everytime the elevation changed or he turned and dragged a wheel. This deck is too heavy for pretty yard work.
3 1/2 FT DISC HARROW (A51247)
3 1/2 FT DISC...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51248)
UNUSED FUTURE MINI...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2014 DRAGON PRODUCTS STEPDECK 46 DOVETAIL W/RAMPS (A53843)
2014 DRAGON...
